Page 1 of 3 123 LastLast
Results 1 to 20 of 44
Thread: Are all these 10+ chemicals really neccessary?
    Apr 2016
    Denver CO
    70
    We have never had a hot tub and just installed one in our vacation rental 1 1/2 hours away. Our cleaner will maintain (but not repair) it. He does other's hot tubs and will check it twice a week for us.
    I tried to educate myself and there's SO much to know and very confusing!
    I found a maintenance schedule online and when I showed it to him he said no one does it that way . Unless they are retired. It showed a certain order to test and add chemicals, and said to wait 30 minutes in-between each!
    I went to Amazon and found about 10 products and am wondering if we need them all. Some we got in our starter kit and some we didn't. Some that we didn't get I think we do need. And some that we did get seem not that important.
    This is the list:
    Chlorine -necessary of course (and test strips)
    Spa Frog-slow release chlorine--yes
    Calcium booster--he says it's not needed
    Defoamer-yes (but we didn't get in our kit so does manufacturer not think it's important?)
    Spa Up and Spa Down-yes (not in our kit)
    Natural Chemistry Spa Perfect/Spa enzyme (for water rings and odors)- in our kit , but is it necessary?
    Clarifier- Leisure Time Spa Bright
    Oxy Shock without Chlorine-yes
    Leisure Time Spa Defender for stains, scale and rust-in our kit
    303 Protectant to clean cover
    Power Soak to clean filter monthly
    TDS test strips to tell when to change the water
    Flush product to add before draining
    Our guy told me clarifier and shocker are the same. Then why does Amazon have 2 separate products? I am starting to doubt him now.
    Any help will be much appreciated!
    38,456
    Re: Are all these 10+ chemicals really neccessary?
    Welcome to TFP!!!
    You need 2 or 3 chemicals to maintain a hot tub. Chlorine, stabilizer, and acid to lower the pH. That is basically all.
    I would not buy anything on that list except the first ... and I would get a real test kit and not strips.
    Honestly, "your guy" really does not sound like he knows what he is talking about. Clarifier and shocker (whatever that is) are certainly not the same.
    Read this: How do I use Chlorine in my Spa (or pool)?)
    Apr 2016
    Denver CO
    70
    Thank you.
    What's is a stabilizer?
    A Shock oxidizes without chlorine and I've read it should be done after each use ideally or every week if not used.
    Apr 2016
    Denver CO
    70
    How is a test kit different than a 6-in-1 test strip?
    I read that these should be tested--ph, alkalinity, chlorine, bromine (I'm assuming one or the other , depending on which you use),calcium hardness and toral hardness. Looking on Amazon, I could find none that do it all-- either calcium hardness or total hardness but not both.
    Both total and free chlorine need to be checked?
    This is about shocking. I wasn't able to do an attachment--
    What is Shock Treatment?
    Shocking a hot tub spa is the application of an ample dose of chlorine (sodium dichlor) or non-chlorine shock (potassium monopersulfate or MPS). One purpose of this treatment is to break-down organic waste contaminants which cause odor and cloudy water. After treatment, water quality and clarity is often completely restored.
    If irritating chloramines are present, shocking also converts them back to active chlorine.
    Regardless of which sanitizer system you use, periodic shocking is essential for clear, clean hot tub water. It will also allow your sanitizer to perform at peak efficiency.
    Non-Chlorine Shock - regular use for maintenance
    Non-chlorine shock is monopersulfate compound, often called MPS for short. It is an oxygen-based shock, preferred by many because it has little or no odor.
    Although not classified as a sanitizer, non-chlorine shock does oxidize contaminants and greatly improves water quality and clarity.
    Dichlor Shock - occasional use to clear up problems
    Dichlor shock is a form of chlorine often called sodium dichlor. Technically it's both a sanitizer and a shock.
    It is recommended for use as a startup shock, and also for occasional use to correct water problems quickly
    Shocking with dichlor (sometimes referred to as superchlorination) is the fastest and easiest way to clear up many water problems such as musty odor, cloudiness, slimy water, algae, etc. Note: dichlor should always be pre-dissolved in a plastic bucket of water prior to addition to spa, to avoid possible damage to acrylic surfaces or vinyl liners.
    When to Shock
    It is a good practice to shock with dichlor when you refill your spa. After that, regular maintenance can normally be accomplished with non-chlorine shock.
    Other times for shock treatment would include: prior to, or just after a party or other period of heavy use, when the spa has been neglected, or when restarting a spa that has not been used for some time. Whenever your regular dosage of non-chlorine shock seems to need an extra boost, dichlor will usually provide it and clear up problems.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Welcome to TFP, check out the link Jason sent you and have fun
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    You could do all that, or you could do it the easy way, the TFP way!!
    As jblizzle said. Read this: How do I use Chlorine in my Spa (or pool)?
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Apr 2016
    Denver CO
    70
    Thanks, I'll check it out.
    Do you think though, that more care may need to be taken when the spa is in a vacation rental (where you don't know what people are doing in it) vs at your home?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    No, just more bleach. I've been maintaining my tub using that process for a few years, it works great!
    38,456
    A little reading here and your eyes will be opened to all the misinformation out there.
    No reason to quote other methods, we do things a simpler and cheaper way that is based on the science and chemistry ... not trying to make a profit. In fact, we are now listed as a non-profit organization
    Apr 2016
    Denver CO
    70
    Well the first part was great but that 2nd part-sanitation-unfortunately won't work for us. The hot tub has been in a week and our pool guy will only be checking twice a week (and at $250/mo at that!)
    Isaac-1's Avatar
    SW Louisiana
    6,711
    You might want to consider getting an SWG for it, there are some retrofit models designed for hot tubs, I personally use one called the Saltron Mini, works great, and when the tub gets little use it is stable enough to run several weeks without testing (not that I tend to do that). I also have a Del Ozonator in addition to the SWG.
    Apr 2016
    Denver CO
    70
    I don't even know what SWG is.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Salt water chlorine generator, you add salt to the water, and it uses electricity passing between metal plates in the SWG cell to break the salt down into Sodium and Chlorine.
    Apr 2016
    Denver CO
    70
    I am not very familiar with that but when I considered it , a friend told me it's more maintenance and tricky to get right than chlorine.
    Sep 2015
    OK
    5
    I feel your pain @Sjde! I was truly confused by the direction the spa store people gave me but once I found TFP and read all the articles in PoolSchool, I now have a better understanding and have been practicing the TFP methods for six months now and my water has never been more clear and balanced.
    Best regards and have fun learning to better maintain your pool/spa.
    LakeLizard
    H2X 19' Trainer Deep SwimSpa, Model 1270. ECO PUR water filter system. 231" X 94" X 60". SwimSpa buried 32" deep with decking/patio built around unit. Spa side capacity = 225 gallons, Swim side capacity = 2045 for a total capacity of 2270 gallons. Ozone system, 4 pumps, 48 jets, LED lights, Aquavibe sound system w/sub woofer. T-100 TFTestKit.
    Apr 2016
    Denver CO
    70
    Just curious about the different optimal levels I'm seeing on different sites. You say, for instance, that TA should be 50, while on another site I saw 80-120 PPM. That's not even close!
    Free chlorine 3-6, another place said 1.5-3 PPM.
    Jul 2013
    Fletcher, OK
    3,353
    For a rental I would also recommend a salt water generator, I used an inline but you need an always on circulation motor, you could get the drop in and it would work great.. .
    38,456
    Lower TA in a spa means the pH will not rise as fast.
    Our FC levels are a function of the stabilizer (CYA) level in the water which buffers the chlorine. 99% of other information posted does not take the CYA level into account and that is why the list lower FC levels (which will not sanitize if there is CYA in the water).
    Have you discovered Pool School yet? Start with this:
    ABCs of Water Chemistry
    Nov 2015
    Ok ok
    823
    I have a salt water generator in my hot tub, virtually no maintenance, rental or not, that's all I would use. At $250 a month to check your hot tub, I think I need to change businesses!!
    ~14K gallon - AquaRite AQR15 SWG - pool Newly plastered on April 9 2016
    TF100 kit - STA-RITE SYSTEM3 Modular Media Filtration - Model S8M150
    Pool water supply from on site water well = CH of ~350 and TA of ~350
    Doheny's Discovery Automatic Robotic Cleaner/Pentair Model 011018 VS Pump
    Sundance Altamar Hot tub separate from pool / central Oklahoma
  20. Back To Top    #20
    Apr 2016
    Denver CO
    70
    This is the system that uses salt water instead of chlorine? I always heard there was more maintenance and trouble with those. And that if I didn't want to be held liable for guest's hot tub acquired infections I should stick with chlorine!
