Results 1 to 7 of 7
Thread: Salt reading showing much higher than actual level
    I have a 13,000 gal in ground pool with a T-3 Cell. Both the cell and motherboard are 1 year old. I am showing 3600 salt, but the pool store is reading it at 2400. I had it checked again the following weekend, still 1000+ difference. I brought the cell in to be checked, it passed. I installed a new motherboard and no change. I tried to reset using the off/auto/off method, but my instant salt reading is within 100-200 of what it's showing originally. The cell previously (month or so ago) had significant build up. I did an acid wash to clean it out. I checked again, and it looks completely clean. Everything is generating with no additional lights, and the pool looks good. I'm not sure what else could be the problem.
    38,371
    Re: Salt reading showing much higher than actual level
    If the SWG is happy, why do you care what the pool store thinks? I would suggest getting your own Taylor salt test.
    A failing SWG cell will read lower than reality.
    Are you sure it's a T-3?
    Can you post the diagnostics?
    Support the site
    Yes it is a T-3.
    3900
    80
    28.1
    3.40
    92P
    -3800
    AL-0
    r 1.59
    My concern with having it read accurately is just that I don't want the cell to not have enough salt to work. Is there a number where there's not enough salt for the cell to generate?
    The numbers look good. Most likely, the store is wrong.
    The TCell number should show in the diagnostic readings.
    About the only way that an AquaRite can show higher than actual salt is if the Tcell type selected in setup is smaller than the actual cell. Sincethe t3 is the smallest cell, it's not possible for the salt to read higher than actual.
    Get a k-1766 salt test kit.
    Support the site
    Just ordered one. Thank you for your help!
    The only way I can think that the salt could read high would be if the cell were bigger than a T3 with the wrong label. However, I would consider that to be unlikely.
    Support the site
