Thread: Hayward S244T Sand Filter-repair or replace?
    Aug 2010
    SW of Kansas City
    100
    I have a Hayward S244T sand filter that is at least 11 years old- it has the pre-2005 drain design. I do not have any records documenting its exact age.
    Problems:
    -Last year and this year, we had a lot of sand in the pool after opening. Last year we were able to vac it up and it did not return. Haven't vac'd yet this year.
    -The drain leaks sand, apparently there is supposed to be a screen on the inside, but it ain't workin'. I had a heck of a time getting the drain cap on this spring without it leaking due to sand that kept streaming out. The threads on the tank are worn also.
    -The multivalve is a bit tight and hard to operate. It doesnt leak but is wet in the notches.
    -The multivalve label is faded and peeling
    -The gauge is shot.
    This is my first Sand filter but it does appear to wrk fine otherwise.
    I'm thinking I can fix this for about $150 or less with new:
    Lateral assembly $60
    Drain screen $10
    Spider gasket $12-15
    Multivalve label $10
    Gauge $10-15
    Shipping/ tax estimated $30-40
    Or...I can get a complete new filter for $295 shipped+ tax...about $320.
    hmm, I may have just talked myself into a new one...
    I did not account for cost of sand, which would be the same either way.
    16'x32' ~20000 gallon Vinyl in-ground pool. Single skimmer + bottom drain, dual return. Hayward 244T Sand filter and 1.5HP 2 speed Super pump running 24/7
    24' round ~13500 gallon Vinyl above ground pool 1HP single speed Pentair pump 24/7 with Sand filter. Next door---Maintaining it for my great neighbor!
    Jun 2014
    15,121
    Re: Hayward S244T Sand Filter-repair or replace?
    Sounds like your gut is telling you wise things. 11+ years is a good run, but may be cost efficient to upgrade at this point. And your itemized list doesn't even include complete multiport valve replacement "IF" it was later discovered that would be needed. I know that's a bit more $$.
    Aug 2010
    SW of Kansas City
    100
    Yep, I was thinking $100 repair, but seeing that the gauge failed and figuring I really need a new label, then adding shipping/taxes, gets it close to half the cost of a new one.
