Results 1 to 8 of 8
Thread: Does anyone else test FC,CC, and TC like me?
    Jul 2014
    Evansville, IN
    72
    I am very much OCD and my data needs to be accurate for me to be satisfied. As a result, I just test the chlorine levels with the FAS DPD 3-4 times per week. Sometimes every day if I notice the Chlorine is changing rapidly. Every day I had approx. 32 ounces of bleach.
    This seems to work- I cant tell that much difference with the color panel test. The top two ranges just seem to be too close to each other. Besides- I am not satisfied reading a result that says the chlorine is between "3-6". I want to know exactly what it is.
    I know it's ok to do it that way- but does anyone else struggle with the different shades of yellow?
    16 x 32 Sport Pool; Hayward Series Sand Filter S244T
    15,000 Gallons, In Ground with New Vinyl Liner
    Pool approx. Five Years Old. Live in KY
    Aug 2014
    Austin, TX
    74
    Re: Does anyone else test FC,CC, and TC like me?
    I wish there was a better way to test PH. I don't have as much problem with the shades of yellow as I do with the shades of orange/pink/red for the PH test. But that said, I pretty much use the FAS DPD test exclusively as well since I'm still fine tuning/verifying my timing for the new stenner pump I just installed.
    12300gal IG PebbleTec w/7' raised Spa & Waterfall. Built Aug 2015
    Pentair IntelliFlo VS Pump, Pentair 420 Cartridge Filter, Ultra UV, Auto Fill
    EasyTouch control w/ Remote, Infloor Cleaner w/1.5HP Pump and Leaf Canister
    Stenner 45MPHP10 w/15gal tank, Rainbow 320 Chlorinator, TF-100 Test Kit.
    Jul 2014
    Evansville, IN
    72
    I cant tell the red colors either
    Jul 2015
    Livingston, Louisiana
    174
    I am exactly the same way with all the tests. I want every test to show the exact number, not a range or shade. I also have difficulty telling how dark the yellow and orange shades are. I find it looks different shades when I hold up against the outside light as opposed to inside against a sheet of white paper. Also the cya test is really difficult with that black dot. Sometimes I think I see it but not sure of how much of it is really visible.
    mkaklis
    27' x 52" AG vinyl, 16,000 gal, Pleatco PAP100 Cartridge Filter, 1.5 HP pump, TK100
    Jun 2014
    15,226
    You are much like the rest of us. Some shades, whether FC or pH, can be a bit tricky and blend well. I had that problem just now the pH on a cloudy day, so I asked my wife for a second opinion. Practice continues to make perfect for those comparator views. Using the OTO, validated by using the FAS-DPD, is a good way to confirm your color reading skills - for FC anyways.
    Jezza's Avatar
    Jan 2015
    Bunbury, WA, Australia
    885
    I also like to exclusively use the FAS DPD as I like the precision of the result. Practice definitely makes a difference- I think that it helps you to overcome your doubts over time with all the tests.
    11 000 gallons, IG, Fibreglass, Monarch Sand Filter, Davey Typhoon C100M 1HP pump, Davey Chloromatic Mc16CTO ESR SWG, Davey Pool Wall Climba Robot, Daisy Solar Cover,
    K-2006
    Jul 2012
    Dallas, TX
    179
    I switched to FAS-DPD in July 2015. "Never again" for the old color shading tests . Well, maybe someday.. "Never say never" .
    I recall being skeptical and a little scoffing about the FC "powder" test when I arrived at this forum and asking "Why get the Speedstir?"
    I ate a large plate of "crow" after converting over to those test tools .
    It's worth the cost trade-off for me but the dye or OTO tests can come in handy for a quick ballpark FC test for troubleshooting reasons.
    - Pool Type: 15k Gal Gunite IG non-SWG / Built 1988
    - Pump: Pentair Challenger / Sweep Pump: Letro Model LA01N .75HP Single-speed / 6 hrs-day (1 turnover)
    - D.E. Filter: OEM: Nautilus (Pentair) #NS 36 / 36 Sq Ft / D.E. Charge: 3.6 Lb
    - Pentair 4-wheel Sweep LL505G - Booster Pump runs ~2 hrs/day
    ned8377's Avatar
    Apr 2015
    Wake Forest, NC
    242
    In the winter or when water is below 60 degrees I seldom us FAS-DPD since I'm not as worried about algae. In the summer, though, I go with the powder almost exclusively. If water is crystal clear I may do OTO for a couple of days.
    True L 45,000 gal Hayward IG vinyl pool. Hayward Tristar 2.40 THP; 1.5 FRHP/1.60 SF. Hayward Model # S310T2 Sand Filter. Aqua Rite T-15. Aqua Comfort 154,000 BTU Heat Pump. TF-100
