Thread: Speed stir question
    Aug 2014
    NJ
    435
    Speed stir question
    When using the speedstir, do you put a drop in and then turn the speedstir on for a couple of seconds and then turn it off before you add the next drop. And then repeat the procedure. Or do you keep the speedstir on while adding one drop at a time?
    1200 Sq Ft 41,000 Gal. Gunite, JANDY SVRS VS pump, JANDY JXI 400,000 BTU, Polaris 280 w/ 3/4 BP, Rockwall and Grotto (w/6 jets and blower), 2 JANDY Lam Jets, 2 LED Bubblers, 5 Ledlights, AQUALINK P16 RS, 90% Quartz, SWF 185 GMP BP, SWF 125 BP, Levelor K1100 Autofill, AP Digital SWG, 2 skim and 5 returns, and mostly 3 inch piping
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Speed stir question
    Leave the speedstir on the whole time. Start it up before adding any reagents and just let it whirl. Add drops about 1 per second until you reach the endpoint color change and the last drop does not change the color at all. Subtract the last drop that didn't change the color at all. Be sure to measure your volume BEFORE putting the stir bar in.
    Isolated Spa - 345 Gallons
    Aug 2014
    NJ
    435
    Thanks. I never did that way. Ill try it.
