Results 1 to 8 of 8
Thread: Salt Connection with Metals
    Noticed that when I introduce salt into the pool that I get the green tint which, short of draining and refilling, is easily solved with sequestrant (Jack's purple stuff). Reaction happens about 30 minutes after introducing bag(s) of salt. I'm curious as to why this happens? I'm using regular salt from home depot at $5/bag vs pool store $30/bag. Are there metals in the salt? Does the salt react with the metals in the water? Figured some of the chemistry majors might be able to satisfy my curiosity.
    35k Gunite, Aquarite SWG T-Cell 15, DE Filter
    Attached Spa, Water Leveler (from well / metals)
    Polaris 380, Jandy RS8 with Aqualink
    Cape Cod, Massachusetts
    JoyfulNoise's Avatar
    May 2015
    13,179
    Re: Salt Connection with Metals
    Can you be more specific about the salt you are using? Is it road salt?
    Pool salt or solar salt (the kind you use in water softeners) is what is recommended.
    Matt
    The kind used in water softeners. 99.9% pure salt written on the bag. Crystals. Definitely not road salt.
    Saturn94's Avatar
    Mar 2015
    Virginia
    496
    My dealer told me there are trace metals in salt. He told me this is why I get staining over time when using the SWCG. I don't know if it's true or not, but so far it's the only explanation I've received that seems to make sense.
    My pool tests negative for metals btw. But it's obvious from the staining that there are some metals in there, perhaps just a very low level. I've been using Jack's Magic Purple Stuff successfully for years to keep stains at bay. I haven't experienced what you're experiencing.
    Oh, and I always use pool salt (I don't have the patience for the slow dissolving solar salt ).
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 with booster pump/Hayward Superpump 1 hp/city water/pool installed March 2004
    Thanks. I guess this will need to go down as just one of those chemistry mysteries.
    38,254
    I have never had any problems with metal staining from adding solar salt.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    I added over 400 pounds and my pool stayed crystal clear.. I used the salt water softener (blue bag) from lowes...
    Aug 2010
    Dallas, TX
    4,052
    Quote Originally Posted by cowboycasey View Post
    1200 lbs in my pool!
