Thread: Descriptive text for link
    Dec 2014
    Riverside California
    482
    When I insert a link into a post, how do I modify the link to show descriptive text for the link instead of just the URL? Been trying to figure this out, but no luck.
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
    Jun 2014
    15,254
    Re: Descriptive text for link
    You can just type phrase you want listed LIKE THIS, then highlight & copy that word(s). Next, just above the text field you see the hyperlink symbol (globe w/ link). Click that, and past your URL to that address, hit "OK". Done.
    38,521
    No need to copy. Just highlight what you want to the the descriptive text, then click the Globe and paste in the URL.
    It will look like THIS : {URL="http://www.troublefreepool.com/content/"]THIS[/URL} with square brackets instead of the curly ones
    You can always edit the text too after the fact if you want to change it.
    Dec 2014
    482
    Thanks, think I got it like...... SO
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    I usually just paste the link and see what it says on its own. If I like it good, if not I edit it.
