Results 1 to 8 of 8
Thread: Do any brick and mortar stores carry the test kits?
    JesseSchmidt's Avatar
    Jun 2015
    Fairfield Twp, OH
    216
    Has anyone found a brick and mortar store that carries one of the suggested kits? I have been to a few and all I'm finding are the dip strips and 2 or 4 way kits.
    26k Gal IG vinyl, Hayward Super 1HP, Hayward Pro Series S244T Sand Filter, TFTestkits TF-100 w/ Speedstir
    Links: TFPC for Beginners / ABCs of Pool Water Chemistry / GETTING STARTED / PoolMath / SLAM / TFTestkits / Chlorine/CYA Chart
    JoyfulNoise's Avatar
    May 2015
    13,173
    Re: Do any brick and mortar stores carry the test kits?
    Sometimes Leslie's will have refills and they have a kit that they say is the same as the K-2006 but it is not.
    Unfortunately, the only way to get the kits is online either through Amazon (K-2006) or TFTestkits.net (TF-100). You can buy online from Taylor too but they are more expensive.
    Matt
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    TFTestkits has really quick shipping. You could probably get one from them in less time than you will spend searching.
    Pool Supply World also sells the TF-100, $68 with free shipping.
    Water Testing - TFTestkit TF-100 Seven Test Kit - TF-100
    chiefwej
    Donldson's Avatar
    NW Ohio
    2,881
    You can occasionally find the k-2006 in pool shops, but they are sometimes rebranded and if you haven't seen one before or they won't let you open it to inspect then it is difficult to tell if it is a rebranded k-2006 or k-2005. You also have to be careful as most people in a pool store aren't looking for a $60 test kit so they might have been there for a while.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    The "Taylor Technologies 81329" at Leslie's is the same as the K2006
    Taylor Technologies 81329 Chlorine FAS-DPD Service Test Kit
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    Wow, $92.
    Better to order the TF-100 online, more of the reagents you use the most and $68 price.
    chiefwej
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    Quote Originally Posted by chiefwej View Post
    Wow, $92.
    Yea Leslie's is stupid expensive for most stuff, although in store prices are sometimes different than online.
    May 2015
    13,173
    Yeah, you can get the K-2006 through Amato Industries via Amazon for cheaper than that. Most pool stores are going to up-charge those kits steeply AND they could be really old.
    Matt
