Results 1 to 9 of 9
Thread: Do I Need A Check Valve & What's That Brass Thing???
    Jan 2016
    Southern CT
    16
    pool equipment pad.jpg We have just finished building our pool and I have a question about our equipment. Between the heat pump and the salt cell there is a brass(?) thing and a flow a flow switch. What is the brass thing? Do I need it? Also, shouldn't there be a check valve where that brass thing is? Sorry to sound vague and dense but I am really new to this.
    36K gal IG Diamondbrite, IntelliFlo VSOM 3HP Pump, Clean & Clear Plus Cartridge Filter, HeatPro 140K BTU Heat Pump, AquaRite AQR15 SWG, Built 1/16-4/16, no H20 restrictions; Hotspring Limelight Flair 310 gal hot tub
    Apr 2013
    Sacramento, CA
    2,769
    Re: Do I Need A Check Valve & What's That Brass Thing???
    I am an old man that can't see. All I see is a brass blur. Could you give me a closeup.
    I don't think you need a checkvalve. The SWG generates limited amounts of chlorine its unlikely to harm the heat pump.
    Jan 2016
    Southern CT
    16
    image.jpgHere is a close up. Is that copper? brass? thing related to bonding/grounding? A green wire runs from the grass to the pump/motor to the sacrificial zinc anode then to this mystery part then to the heat pump.
    sargent's Avatar
    Aug 2013
    Tulsa, OK
    291
    14k gal IG vinyl, Jandy Flopro 1 hp up-rated, 2 spd pump, Hayward 325 sq ft cartridge filter, Circupool Si-40 SWCG
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Yep. Anode.
    Nope. Don't need a check valve there. That other fitting down stream of the anode is a flow sensor for your SWG. If it doesn't detect flow, it will shut down so it's effectively a check valve. No flow = no chlorine production to back flow into heater.
    Isolated Spa - 345 Gallons
    22,543
    Actually I think that particular fitting is a water bonder. But, it does look like you have an anode in the line between the filter and the heat pump.
    It also looks like they have the nut on that split-bolt turned around backwards.
    As for the check valve, you don't really need one.
    Jan 2016
    Southern CT
    16
    Thank you all. Mystery solved and no need to add a valve.
    38,254
    Yeah, I think that brass bar in the bolt slot supposed to be between the wires and the nut.
    Jan 2016
    Southern CT
    16
    Thanks! I will get that taken care of.
