Thread: Should I adjust my Calcium Hardness?
    Apr 2016
    Youngsville, LA
    274
    Current setup is a 15k gallon SWG gunite/plaster pool (built in 08-09) and spa. Current CH level is 170. Kinda confused at all the different numbers/recommendations for CH. Should I bump this up a little, and if so what range should I shoot for 200-250? The previous homeowners left a 5 gallon bucket of Hardness Plus which makes me assume that the pool's CH levels must have stayed on the lower side.
    15k Gallon In Ground Saltwater Gunite Pool and Spa w/ Overflow
    Dolphin Nautilus Plus Pool Cleaner
    Main Filter Pump - 1.5HP Pentair Whisperflo connected to Triton II Sand Filter
    Spa Pump - 2HP Pentair Whisperflo w/ 2HP Polaris Spa Air Blower
    Resilience PSC3 SWCG
    Jun 2014
    15,198
    Re: Should I adjust my Calcium Hardness?
    The CH range for your SWG pool is 350-450. It would be in your best interest to stay close to that minimum end of the range to protect your pool's plaster surfaces. Some people who live in areas that have hard water see their CH rise quickly from refilling. The links below in my sig can help you with that as well. If your area receives so much rain that water exchange happens quite frequently, or you pool has a constant leak, that can result in CH lowering quite rapidly. Hope that helps.
    Apr 2016
    Youngsville, LA
    274
    Quote Originally Posted by Texas Splash View Post
    Well our pool isn't that big beings it's only 15k gallons and it tends to rain quite often in South Louisiana, therefore every so often I do have to waste from time to time to lower it back to the proper skimming level. Maybe that's why it tends to stay on the low side for the CH. I'll try raising it up a bit and see what happens. Last thing I want is for the plaster surface to get messed up due to low CH levels.
    Jun 2014
    15,198
    I think that's a good call. I forgot to mention the backwashing, so yes that would definitely impact your CH (and CYA) levels. Have a nice weekend.
