Results 1 to 17 of 17
Thread: Pasting photographs from Photobucket
    Oct 2015
    Coral Springs, Florida
    79
    Am trying to post pictures from Photobucket using the paste icon. When I hit the icon, it says "Paste as plain text". I can't seem to find the procedure for post as photograph. Anyone who is far less technical challenged than me have any clues? Thanks very much.
    30 x 15; in ground; about 16,000 gallons; Diamond Brite (applied 06-2015); Hayward AquaRite salt chlorination (t-15); Hayward filter (CX900-RE/PXC-95); Century V-Green 165 variable speed motor; all located in south Florida.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Re: Pasting photographs from Photobucket
    Quote Originally Posted by Henry M View Post
    Right above the compose box you see icons to switch to bold fonts, increase font size, insert a hyperlink, and paste an image. The image icon looks like a picture frame, I guess. Hover over each icon and it will tell you what it does. When you click it, a popup window appears. Select "from URL", paste the address in, and uncheck the "Retrieve remote file and reference locally" box lest you use up your allotment of space too fast.
    Alternately, you can type (close up the spaces) [ img ] before the URL and [ / img ] after it.
    Oct 2015
    79
    Tried both, and still only text appears, not photo. The photo I want to paste is also on my computer. I tried that, using the paste icon, and got a message saying I used up too much space. What am I missing?
    Richard320's Avatar
    Jan 2010
    19,023
    You used up your allotment of space posting the pictures of your stains.
    You want the direct link, not all the mumbo-jumbo they put along with it. The file name should start with http and end with .jpg
    Try just pasting the URL and let us look at it and see if we can make it an image.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Copy the IMG code to the right of the pic in Photobucket and paste it in your post. Don't use any of the icons in TFP. Just a straight paste.
    Oct 2015
    79
    [IMG]http.//s446photobucket.jpg[/IMG]
    The above is what I got using the Insert Image icon
    Oct 2015
    79
    Many thanks for your input. OK; I hit IMG on photobucket; yellow sign indicated "copied"; but I don't know how to paste it my TFP post. Is there an additional step I need to take on the Photobucket site? Is there anything I need to do on the TFP site to paste it?
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Just right click and hit paste inside your post, check out the "how to post pictures" in my signature below
    DFW, TX
    24,497
    Right click and hit paste or hit CTRL+V
    Oct 2015
    79
    I think I've got it. Many, many thanks to all of you for having the patience to deal with one who is severely technologically challenged.
    Oct 2015
    79
    But I've another question about attachments to posts on this forum. Is there a way to delete attachments?
    38,305
    Yes, but why? Then your old threads will not make sense to anyone that looks at it in the future.
    kk_isme's Avatar
    Aug 2015
    North Central Texas
    108
    Question. Why use photobucket? It seems to me it's easier to skip photobucket and just upload straight from your PC or tablet. That's what I do. I've never used photobucket.
    14,000 gallon above ground 24ftx56in round vinyl overlap liner steel wall sand filter 1/2 hp pump heavy lime in city water morning shade
    Oct 2015
    79
    Good point jblizzle; hadn't considered that perspective. To kk_isme: I tried attaching direct from my PC recently, but got a message about having used up the allotted space for attachments to a post I made last year. It appears that once you've used whatever space is allowed for attachments, that's it; you can't attach anything anymore, which creates the need to use another source, like photobucket.
    38,305
    Because if you are not a supporter, you have very little storage space at TFP.
    Although it would be best if everyone was a supporter and stored the pictures locally, so links may not get broken.
    Oct 2015
    79
    Just became a silver supporter
    38,305
    Great! Thanks for helping us keep the lights on without advertisers.
