Thread: Spa blower cap cracked and blower failed - replacement easy and quieter
    Nov 2015
    Carrollton tx
    451
    I think the blower was Original with the pool - 2000
    I failed to notice the cap was cracked and water got in
    the "filter" material had all broken down as well - turned to dust when you touch it
    I know some here think the blower is a patch for poor plumbing
    but even with 2 vs pumps the spa wasn't very spa like so I purchased a replacement
    1.5 hp 220 volt Polaris blower - I picked the QT model
    the install took maybe 15 min and the noise difference is impressive
    much quieter and makes a difference to the appearance of the spa
    The neighbors will really appreciate it
    Doug - Purchased 1/2016, 1995 house with 16x31 ft, ~23000 gallon Gunite pool w 11x7 spa, 3 Pentair VS pumps, a boost pump for polaris 3900 and a BaduŽ Jet super-sport swim jet pump, 1.5 hp blower, a CL460 Cartridge filter. TF-100 test kit. Aquapure SWG, iAqualink - Lots to learn. New Aquabright, Jandy LEDs, CMP LED Sheers.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Spa blower cap cracked and blower failed - replacement easy and quieter
    Glad it worked for you!
    Essential Links:
