Thread: Haywood e-command breaker question
    Apr 2016
    Highland village tx
    7
    Hi guys, been following this forum with interest and learning alot about pool chemistry.
    Im in the process of upgrading my control unit, my e- command 4 has just arrived and have a question about relay and breaker wiring.
    I have filter pump 220v 9amp 1.5hp
    Water fall pump 220v 9amp 1.5
    Blower 220v 4amp
    Heater 220v ?amp only used for heating spa when needed.
    Fibre optic lights 120v
    Pumps,blower and lights will go to my 4 relays.
    Wondering what wiring configuration you would recommend, i was told heater doesnt need relay.
    Any suggestions would be greatly appreciated.
    38,284
    Re: Haywood e-command breaker question
    Welcome to TFP!!!
    Just follow the wiring that the manual shows
    The heater will need its own breaker and is turned on and off by control wires to the automation system.
    Each pump needs to be its own breaker as well.
    Light on a GFCI breaker (or off of a GFCI outlet). This circuit may also be able to power the blower.
    Apr 2016
    Highland village tx
    7
    Wiring in the manual is pretty straight forward, just shows how to wire relays for 220v or 120v, i have to supply breakers for the box. Just wondered if i could have pump and heater from a 20amp breaker then other pump and blower on another 20amp breaker. Do lights need to be on gcfi with them being fibre optic?
    Thanks for feedback
    38,284
    I posted before my breaker recommendations.
    I do not know about the fiber optic GFCI requirements.
    Jun 2012
    western NY
    1,560
    The GFCI requirement for the fiber light generator all depends on the location and how the location of it is viewed from a code perspective. As it stands now, anything in an outdoor location HAS to be on a GFCI. Pool houses, garden sheds and garages all require GFCI protection for all of its circuits. However, I did recently came across a situation with a pool house that the circuits did not need to be GFCI as it was considered living space (fully finished with heat and cooling). This somewhat dovetailed in with the GFCI codes for basements. A finished basement does not require GFCI protection in the finished area but, still does in the unfinished part. I am not able to give you the definition of what is considered finished space. My assumption for your case is,...yes, GFCI the circuit for the light.
    Dan
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
