Results 1 to 11 of 11
Thread: Plranger: troubled and confused
    Apr 2016
    Arab Alabama
    4
    i just purchased a new liner for a old pool (above ground) last year. Now I need to replace my pool. The problem is the hole for the skimmer are not the same size. What are the odds of me being able to successfully patch the hole? thanks Phil
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Plranger: troubled and confused
    Welcome to TFP!
    I'm a little confused by your post as well. You're wanting to use the liner you purchased for your old pool on a new pool? Is it possible to use the skimmer from the old pool with your new set up?
    If you could fill out your signature with details about your pool, that would help. Edit Signature
    Isolated Spa - 345 Gallons
    Apr 2016
    Arab Alabama
    4
    No the old pool is 11 years old and in that time they seem to have gone from a square skimmer to a rectangle. The holes in the pool wall are cut into them from factory. I have talked to several people and get completely different answers.
    27 ft above ground pool with salt water, the pool is 11 years old. the liner is a year old, I added the salt system 3 years ago. the company that made the pool has been out of business.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,600
    What they've gone to is referred to as a "wide mouth" skimmer.
    Apr 2016
    Arab Alabama
    4
    has anyone tried to patch a hole in the liner
    that big with any success? the size of the square skimmer hole
    38,283
    So your pool has a square skimmer, but the liner has a rectangular hole?
    Could you change to the wide mouth skimmer?
    Casey's Avatar
    SW PA
    10,438
    Welcome. Pictures would help a lot.
    Apr 2016
    Arab Alabama
    4
    The holes in the pool are precut for the skimmer that comes with the pool. thanks for the response. i didn't know the question was complicated. i have seen patch kits for sale, but I also have had people tell me that you can't patch a hole that big successfully.
    Jun 2015
    Charlotte, NC.
    82
    Question isn't really complicated, we just are not understanding exactly what you want to do. Pictures would certainly help.
    Reading the above it appears that your liner came with the wide (rectangular) holes, but you pool has the old square holes (taller but less wide?). Can you give us the dimensions of the liner holes and pool holes so we can understand exactly how much patching would need to be done? How many skimmers need to be patched?
    Is it too late to return the liner and order the one with the correct skimmer holes?
    Would it be easier to replace the skimmers with the correct style as opposed to patching the liner?
    - Matrioux
    2007 18K pebble IG pool - Wincor Pool Systems automation & SWG (under development) - DE Jandy DEL60 Filter - Jandy 1HP Pump - TF-100 Test Kit
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Is it a metal side pool, could you cut the wide skimmer out of the pool to match the liner.. the wide mouth skimmer gives better skimming action
    Casey's Avatar
    SW PA
    10,438
    Are you trying to use an old liner that you bought last year and installed in your old pool in a new pool?
