Thread: Broken pressure gauge?
    Jun 2014
    Markham/Ontario
    52
    I found my sand filter pressure gauge reading 40 psi when i went to open the pool after the winter.
    It was just stuck there at 40. In the past it would be at 20 psi after a back wash and 30 psi when the filter was dirty.
    I decided to go ahead and still open the pool and buy a replacement the next time I am at the local pool store.
    After opening the pool the gauge now reads 60 when the pump is running and 40 when it's off.
    Do you guys think that the gauge is broken or is there a way to reset it so that it drops back down to 0 when the system is off and not pressurized?
    15K Gallons, IG, Vinyl, 1HP Single Speed Pump, Sand, SWG, NG Heater + Solar Panels
    Jun 2014
    15,189
    Re: Broken pressure gauge?
    Not sure there's a good fix other than a really big hammer You know you can always order a really nice one from TFTestkits.com (same as TF-100 link below) for about $12. Nice glycerin-filled, top or side mount. Just a thought.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,409
    The gauge is broken. I would not recommend tapping it with a hammer since they are threaded to screw into the filter. You can order the nice one Pat mentioned or you can go to your local hardware store and pick one up. You just need to know the correct diameter for the threaded post. If you get it from a pool store it will cost about $5 more.
    Love TFP? Become a
    TFP Supporter!
    Jun 2014
    Markham/Ontario
    52
    Quote Originally Posted by Texas Splash View Post
    I would love to get the gauge from TFTTestkits.com, but unfortunately they don't ship to Canada.
    Jun 2014
    15,189
    I wasn't recommending tapping, I meant a full-blown sledgehammer. Kidding of course. Well, definitely a local replacement then. Good luck! Once you get the old one off ... then get the sledgehammer.
    JoyfulNoise's Avatar
    May 2015
    13,231
    Quote Originally Posted by g5marek View Post
    Sent from my SGH-I747M using Tapatalk
    You can order glycerin filled gauges on Amazon.
    Winters PFQ Series Stainless Steel 304 Dual Scale Liquid Filled Pressure Gauge with Brass Internals, 0-30 psi/kpa, 2 Scientific
    They have both bottom and side mount. More expensive that TFTestkits but you're in Canada so....
    Matt
