Results 1 to 10 of 10
Thread: cc high
    Kathe's Avatar
    Jun 2015
    Saline, MI
    47
    cc high
    My CC is at 1 and I was told to add a non-chlorine shock oxidizer called "shock and swim." How serious is a high cc? I have noticed that the FC is going fast. My CYA is at 30. My pH and TA are fine. Water is clear.
    I have a little bit of muck at bottom of pool that I haven't vacuumed out yet. Water is too cold to get into. If I use the oxidizer, will that help with the FC?
    Above ground 27' round, 17,000 gal., 52" high; vinyl liner; TropiCal 96,000BTU Heat pump; Integrity A Frame Ladder; Solar Blanket, Aqua Cover by PolyAir Corp, thermotex clear, 5 yr. warranty, cartridge filter., Clear Bay Cartridge CBA2-10043 (two to switch out when cleaning); New pool as of 6/1/15.
    Jun 2014
    15,261
    Re: cc high
    Here at TFP, a CC over .5 is alarming. That along with your FC loss would indicate algae forming. We perform what is called SLAM (link below) to remove algae from a pool. Oxidizer won't work. You need to use regular household bleach in applications based on your current CYA - in your case you need an FC of 12 to be maintained 24/7 as noted on the SLAM page. You'll need the right test kit (TF-100 link below) as well to perform the SLAM properly. Take a look at our Pool School and SLAM pages for details.
    Hope this helps.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,073
    Re: cc high
    Quote Originally Posted by Kathe View Post
    If you added the non-chlorine oxidizer at all before you tested, it could be giving you the CC reading.
    https://www.taylortechnologies.com/C...P?ContentID=24
    If you have debris in the pool and you're using a lot of FC -- more than 3 FC per day -- and you have high CC, then you need to SLAM using bleach. Once you start using that other "shock" you won't be able to know if the CC is eliminated or if it's interference.
    Kathe's Avatar
    Jun 2015
    Saline, MI
    47
    Re: cc high
    I have not yet added the oxidizer. I won't. I'll go back to pool school. Thanks!
    Kathe's Avatar
    Jun 2015
    Saline, MI
    47
    Re: cc high
    Do I have to get rid of the little bit of muck to have a successful slam?
    Which is better kit? The TF-100 or the Taylor K2006?
    Richard320's Avatar
    Jan 2010
    19,073
    Re: cc high
    Yes
    TF100 is a better value.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,198
    Re: cc high
    they both have the same Taylor reagents, just in different qualities. As Richard stated, for a residential pool the TF-100 is the better value.
    Support the site
    Kathe's Avatar
    Jun 2015
    Saline, MI
    47
    Re: cc high
    One more question....is the TC and FC ever truly 0 on a regular basis? Is there a range of cc that is ok? like 0-.4?
    Richard320's Avatar
    Jan 2010
    19,073
    Re: cc high
    No. In a perfect world FC = TC, but not ever zero. No matter what the CYA level, you need some chlorine in the pool to sanitize it.
    If CC is .5 or less, we consider that the same as zero.
    Kathe's Avatar
    Jun 2015
    Saline, MI
    47
    Re: cc high
    OK! Great! Makes more sense to me now. Thanks!
