Thread: 2hp Hayward plumbing question
    Apr 2016
    NY
    3
    First post. Hope to get some answers. I have a 20x40 in ground pool. The underground piping is all inch and a half. All of the above ground piping, jandys, and multiport are two inch.
    I'd like to upgrade to a 2hp hayward. I'm concerned I may starve the pump. Would the inch and a half suction lines provided enough water?
    Any thoughts would be appreciated.
    Tom.
    38,508
    Re: 2hp Hayward plumbing question
    Welcome to TFP!!!
    Which pump? A 2HP SuperPump is much smaller than a 2HP Super II. The HP is only part of the story.
    Why do you think you want a bigger pump?
    But, no can not really "starve" a pool pump with 1.5" pipes. The smaller pipe will just raise the head loss and lower the water flow some from what it could be with larger pipes.
    Please add your pool details to your signature as described HERE as it will help us help you.
    Apr 2016
    NY
    3
    I went to my original pool builder today. Pool was built in 2004. Composite walls, and (2) inch and a half suction lines. He claims that because I have two suction lines it should be fine. He would be concerned if I only had one suction line. The exact model number for the new pump is sp2615x20. Think I'm going to go ahead and do it. Thoughts?
    20x40 inground pool
    Slide, Polaris jet, Two returns
    2 Skimmers 1 Floor drain
    Inch and a half piping in ground
    Two inch piping and valves above ground
    38,508
    Welcome to TFP!!!
    Apr 2016
    NY
    3
    Sorry for the delay. My 1.5hp hayward isn't giving me enough pressure at the returns, with two water features. Was hoping for a little more pressure at the returns to help move the surface debris to the skimmers.
    20x40 inground pool
