Results 1 to 7 of 7
Thread: New spa/hot tub owner
    Apr 2016
    CA
    5
    Help needed
    We just moved in and inherited this spa/hot tub .Want to avoid paying 95/mth for water checks and do it myself .Was hoping to drain and refill and start fresh (dont know when it was done last) .Have been unable to see any branding/tags /labels to learn about the spa ...does anyone know what brand this might be and if not can u help w the following :
    -How to drain it sump pump or is there a built in (using aqualink RS)
    -where would i find the filters ?
    - there is a water feature but no pool or other drain outlet that i could find ....
    Any help is appreciated 🙏🏼
    Apr 2016
    CA
    5
    Hi we just got a house that cane with a spa/hot tub .I want to do my own maintainence on it but am unable to locate the brand or user manual etc.
    Unable to post pics but it is a in ground standalone hot tub w water feature .
    I cant see a drain or any branding on it .It is linked to a aqualink rs/Jandy remote which works fine .
    I would like to drain refill swap out filters but havent found anywhere i could flip open to access those .
    Please help
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Re: Help needed
    Welcome to TFP!
    Get some Ahh-some and add it to your tub to clean it, then drain and refill. Here is the process I have used for several years to start up and maintain my tub. Works great! How do I use Chlorine in my Spa (or pool)?
    Most hot tubs have a drain hose at the bottom below the control panel. Sometimes they are behind the service panel, also below the control panel.
    Apr 2016
    CA
    5
    Re: New spa/hot tub owner
    Here are the Pics ...Problem is I cant find the Drain pipe or a physical control panel on the tub .It is controlled by the separately located Aqualink Panel
    Apr 2016
    CA
    5
    i just put up pics ...could u advise on how to proceed with draining it and also where to find the filters ...to change.
    Appreciate any help in advance Thanks !!
    DFW, TX
    24,483
    Hey, that's an interesting way to plumb a hot tub! I have never seen that before. I do not see a filter, unless there is something inside the skimmer door. I don't see a way to drain either. You can start a siphon with a hose or get a small sump pump.
    Apr 2016
    CA
    5
    Thanks again ...I am scratching my head regarding those two.Interestingly there are no labels or markings on the Tub either to show the manufacturer etc.
    Appreciate your response. I have just ordered a sump pump and plan on cleaning it out this weekend and filling iot ...now onto buying and learning about the chemistry of it
    Quote Originally Posted by pooldv View Post
