Thread: Pentair Intelliflo LCD screen backlights and buttons work, but nothing on Display
    Apr 2016
    Carlsbad, CA
    107
    Hi-jacked someone else's thread yesterday, figured I should start my own instead. I have the 011018 Intelliflow, just out of warranty (of course). Pump works fine, but after a power outage a month or two ago, the timer reset, and I have nothing on my LCD screen. All the buttons work, and the backlight on the screen is illuminated, but there are no words/images on the screen. I can still turn it on, and switch pump speeds, but cannot program or see anything.
    I read the other threads dealing with loose contacts on the LCD screen, but when I went to take the screws off, I realized to get to the back of the LCD, I need the specialized hex screws on the wider plate for the pump. The three phillips only take off the outer case, and the PCB etc are below the rubber seal. I don't want to break the rubber seal, so I guess I need a specialized screw head to remove the screws?
    Any suggestions appreciated
    Carlsbad, CA
    17,500 gal rectangular Midnight blue Quartzscape, Pentair Intelliflo, Poolstore Vergnugen, Aquarite Salinator renovated 2016 Spring
    ColdAirGuy's Avatar
    California
    85
    Re: Pentair Intelliflo LCD screen backlights and buttons work, but nothing on Display
    I've had the same thing happen with my pump a few times over the last couple of years. Each time it has self-corrected with a simple cycle of the power. I did see the thread you mentioned as well and anticipate having to open my panel up in the near future for a look.
    Anthony 16,000 Gallon Oval, White plaster, 30' Long 15' Wide 5 1/2' Deep end 3 1/2' shallow end.
    Pentair Intelliflo, FNS Plus 60sf. DE, Pentair Intellibrite 5G
    TF100 Testkit
