Thread: Question about CSI
    drestes's Avatar
    Sep 2013
    Rome, GA
    34
    Question about CSI
    Hi all - I tested my water today and everything looked to be in range. Below are my test results:
    FC 4
    CC 0
    pH 7.5
    CYA 70
    TA 60
    CH 50 (pool is vinyl liner)
    Salt 3300
    Current Pool Temp 76
    I plugged my results into Pool Math and got a CSI of -1.35, well outside the suggested range. Do I even need to be worried about CSI since my pool is vinyl? I don't have a great understanding of the whole CSI thing
    18 x 36 vinyl liner IG pool, grecian shape, ~27k gal
    1.5 hp Hayward Super Pump, Hayward DE3620 Filter
    Hayward Aqua Rite Electronic SWG, Dolphin Triton PS robot
    TF-100 test kit with SpeedStir
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    Re: Question about CSI
    It says
    Less than -0.6 is suggestive of problems for plaster, tile, stone, and pebble pools.
    Greater than 0.6 is suggestive of problems for all pools
    So don't sweat it!
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    That's right. Vinyl pools only need to worry about high positive CSI, above 0.6.
