Thread: New Pump
    New Pump
    I have a Jacuzzi Magnum 1.5 hp pump. The motor been replaced around 2008. Last summer the motor died. Should I replace the motor or get a new pump? I live in upstate NY and the system is old. I bought a new DE Filter to replace the sand one the previous owners had.
    Thank you.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: New Pump
    If the wet end of the pump is still in good shape, I would only replace the motor as it's usually cheaper. Look into a dual speed motor for a good option to add some efficiency and flexibility. You could also go to a variable speed motor but they tend to cost a bit more and give even greater flexibility.
    Also, if you fill out your signature with details about your pool and equipment, you'll get better recommendations and advice. Edit Signature
    Isolated Spa - 345 Gallons
    Re: New Pump
    done. thank you.
    IG 15000gal Liner. Hayward DE 75. 1.5hp Jacuzzi Magnum single speed. Oval pool built in 1985. Buffalo, New York.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: New Pump
    If you are interested in using a lot less electricity and gaining versatility and functionality a variable speed pump is a good choice. Like this one, Pentair SuperFlo VS Pump 342001 | Pentair 342001
    Or a two speed pump will also save quite a bit of electricity. Here is one, Pentair SuperFlo Pump 340043. Pentair 340043.
    Re: New Pump
    Thank you for the recommendations. Think I will go with the VS pump.
