Results 1 to 10 of 10
Thread: Help just got my pool sparkling clean AND THEN !!
    Brought pool from pond over winter to sparkling blue .I used around 35 bottles of mostly 8.25 chlorine house brands ,concentrate no extras last few 10% from lowes got all debris out and vacuumed.Checked FC last night non recorded PH needed raising ,so I used twenty mule teen detergent booster last night checked twice and added more this morning. went to dollar general this morning bought 4 two quart bottles of concentrated 8.25 bleach no extras .The pool was sparkling about an hour later my wife said why is the pool green,I thought she was kidding .My question what is the most likely culprit Borax is it possible the bleach or the fact that the FC did not register pool temp 76 cloudy day and I put one gallon bleach in not enough??
    Help I was floored when it turned green best guesses please can't now but I plan to hit Lowes this afternoon for 10 % Thank you for suggestions
    Haven't tested yet ,but CYA probably 0 the way the chlorine disappeared
    A couple of hours later I looked out and it was sparkling again It must have just been a quick bloom before the chlorine kicked in I'll test this evening expect to add stabilizer and more borax 20 Thanks for the info today I love BBB with my vinyl liner so inexpensive to maintain to bad some are addicted to the pool store
    Well son of a gun felt safe and put another gallon of Dollar general bleach in and now I am green again this is the quart size I haven't used it before
    GPMIDWAY 18X33 AGP 2HP CARTRIDGE 2 SPEED
    WINSTON SALEM NC
    Jun 2014
    15,149
    Re: Help just got my pool sparkling clean AND THEN !!
    Two quick questions:
    1 - Do you fill with well water or any source known to have metals?
    2 - Can you post a full set of test results from your TF-100 or Taylor K-2006?
    That would help tremendously.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    I'll take two questions too.
    Is it green and clear? Or green and cloudy?
    Take a look at this, Pool School - Metals in the Water and Metal Stains
    green and clear
    Water is from city no difference except rained last night
    WINSTON SALEM NC
    Jun 2014
    15,149
    That could be metals. You might want to see if you can take a water sample from your source (hose) to get tested or call your local environmental office to inquire about metals (iron) in the water. It's possible the higher chlorine is causing that reaction, and if not controlled quickly, the metal will precipitate out to the pool surfaces and cause staining. If that's the case, you'll be one of those pool owners who has to manage their pool accordingly. You'll want to read this page: Pool School - Metals in the Water and Metal Stains.
    I'm afraid to put the other bleach in without going to Lowes
    WINSTON SALEM NC
    Jun 2014
    15,149
    Maybe post a pic for us to see and validate?
    WINSTON SALEM NC
    Jun 2014
    15,149
    Big difference in that top pic. Before we get too far ahead of ourselves, it's still good to ask ... can you also post a set of test results? It's best to rule-out anything chemical related before running down too many different roads.
    Have the grand kids right now going to have to wait till afternoon I suspect CYA 0 ans I just got a fresh bloom because I didn't put bleach in last night
    WINSTON SALEM NC
