Page 1 of 3 123 LastLast
Results 1 to 20 of 55
Thread: Black Stains Fibreglass
    Nov 2014
    United Kingdom
    220
    Hi
    I have a problem with black staining on my fibreglass pool
    It's not related just to the fibreglass because it is happening in the plastic weir as well
    I have used Lo-Chlor Black algae killer to no avail
    A stainless steel wire brush moves it but very slowly
    Jun 2014
    15,059
    Re: Black Stains Fibreglass
    Hello Dennis! Let me ask you this first .... do you have your own test kit over there, and if so, what kind is it? We really need a full set of water test result to help pinpoint what the staining might be. I know some testing products are hard to obtain away from the U.S., but knowing those chemistry levels is extremely important to differentiate between the different causes (i.e. algae, calcium, etc).
    Nov 2014
    United Kingdom
    220
    Hi Pat
    I use the Aquachek meter and strips as test kits aren't readily available
    Chlorine 3
    PH 7.4
    TA 120
    I haven't had this problem before and the pool is checked regularly
    I use sodium hypochlorite 14/15% and reduce my TA with Muriatic acid and raise the PH with aeration
    Jun 2014
    15,059
    A couple important items missing are CYA (stabilizer/cyanuric acid) and CH (calcium hardness). The CYA will tell us what your FC level should be, and the CH would indicate any irregularities that may cause calcium staining. I'm afraid I'm not real familiar with the Aquachek meter, and strips don't have much of a good reputation around here. But I understand your options are limited. You might however want to check about trying to get the Taylor K-2006C on eBay. I've heard some folks overseas have been able to get it that way. My initial thought was that you have a type of algae on those walls, but I would expect your FC to drop rather quickly if that was the case. Sometimes we get that black scum line appearance around the edges of the pool and in the skimmer, but I've not seen that same reaction below the water and on the walls like yours. Since you don't have a CYA listed (not sure if you can test for it), you might at least try increasing your FC to around 6-8 ppm for a few days to see if that changes anything. If you have a chlorine tablet, try rubbing it around on one of the walls for a couple minutes, careful not to keep it in one place too long. If the black fades or disappears, you know it's organic and a higher FC level would be required. You can refer to the SLAM page (link below) for more details on that process. I hope this info helps give you some direction and ideas next.
    Nov 2014
    United Kingdom
    220
    Hi Pat
    I've ordered the recommended test kit
    The water level has dropped a bit, can I rub some liquid chlorine onto the stain above the water level to test
    Jun 2014
    15,059
    You could try that, or perhaps try it a little diluted (50/50) first to be safe. Rinse well after you've tried it to see if it had any effect. Good job ordering one of the recommended kits. Makes a HUGE difference. Have a nice weekend.
    Nov 2014
    United Kingdom
    220
    I poured a lot of sodium hypochlorite 13-15% into the skimmer weir and left overnight with the pump off. There was no difference to the staining. It wasn't even soft to scrape or brush off.
    The Test kit could take 3 weeks to get here
    Jun 2014
    15,059
    Wow. Okay then, perhaps not organic. One other thing you might try. Put some muriatic acid in a spray bottle or maybe on the end of a brush and put a small amount on the black material that is exposed above the waterline. No need to let it sit for real long, and of course be very careful with safety (skin and eyes). Rinse the area after the test. But I would be curious to know if there is any reaction when applied (i.e. bubbling). I will be very curious to see what your test results show when your kit arrives.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,770
    Greetings, Dennis and welcome.
    Did the staining suddenly occur, eg after shocking/slamming, or has it evolved over time?
    What is your water makeup source? Are you on a well?
    Do you use metal sequestrants? If so, do you maintain same weekly/monthly? Or is the pool new to you?
    Do you normally use Algaecides that contain copper?
    That *could* be maganese staining, or copper staining that has partially reacted to oxidization (was it a different color before?)
    I don't know if you can readily obtain a "jacks magic stain ID kit" -- if you can, that may help sleuth out the best treatment route.
    If you can crush up some vitamin c (ascorbic acid) and hold it in the pool against a stain for a few minutes, please tell us if it lightens or turns blackish. That might get us started.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Nov 2014
    United Kingdom
    220
    Firstly
    I topped up the pool shortly after checking but I pulled out the flap (and broke it) from the skimmer weir and poured muriatic acid on it. The stain disappeared immediately (no bubbling)
    Secondly
    It seems to have evolved over time
    We are on mains water supply and the water is hard
    I don't think i've used metal sequestrants
    The amount of algaecide I use is negligible
    I don't think it was a different colour before
    I have sent an email to Jacks Magic to see if they have a UK agent
    I will get some ascorbic acid to test
    I suspect that it's probably copper from the algaecide.
    Support the site
    Jan 2012
    'burbs of Augusta, Georgia
    7,306
    Quote Originally Posted by JamesW View Post
    That was my first thought too.
    Dennis, does your local pool store offer any testing for metals? Could you bring a water sample in and have them check for them? There is a test kit available here but not sure about there.
    Yip
    Lo-Chlor Black algae killer is at least one source of copper.
    Support the site
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Nov 2014
    United Kingdom
    220
    Hi All and thanks for your input
    We don't have pool stores here. I suppose the market isn't big enough
    Lo-Chlor Black algae killer was put in after the staining
    I have already contacted Jacks Magic Stain Identification Kit regarding a local distributor or retailer
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,770
    Dennis, can you please add details to your profile signature line so that we know what kind of surface etc. you're treating?
    Another tester just had success on copper stains that had turned black using muriatic acid with the tool I will link below...this is likely only a suitable approach for plaster...and would still require some metal sequestrant, i suspect...
    Not especially cheap, but it seemed to work well for him:
    Amazon.com: Purity Pool UAW Underwater Acid Wash Set: Patio, Lawn Garden
    (Since the MA worked on it.)
    Helpful Links:
    Nov 2014
    United Kingdom
    220
    I did mention that the pool was fibreglass and it's in the title
    However I will add to my profile
    I will wait till I get the test kit before trying Purity Pool UAW Underwater Acid Wash Set.The only thing that bothers me about it is that the black staining is widespread and how much acid will be in the pool. Unless a load of acid in the pool could cure it anyway and then neutralise after.
    Opinions please
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,770
    Oops, doh, sorry re fiberglass...sometimes when i come back to a post the second time I don't notice the title.
    I'm not especially familiar with fiberglass care but in general, you would likely want to stop after using a certain amount of MA via the siphon and rebalance your ph before continuing. Eg. Depending on PoolMath calculations, if you know that half a gallon will drop you x-amount, only use that much in a single session.
    Lets see if someone with more FG similarity chimes in.
    Helpful Links:
    Jun 2014
    15,059
    ha ha. I had a feeling you were going to say something like that when you came back.
    Also might depend on the age of the FB and if it has calcium carbonate in it. Might be difficult to determine over there, but certainly warrant being extra careful.
  20. Back To Top    #20
    Nov 2014
    United Kingdom
    220
    Quote Originally Posted by Swampwoman View Post
    That makes sense. Will probably be a big job but if there is light at the end of the tunnel it will be worth it
    10,000 gallons inground Leisure fibreglass pool, Hayward powerline pump, Quality120 glass media filter, 27kw output air source heat pump and thermal cover.
    Retractable cover with Polycarbonate roof and glass side for all year round use. K-2006C test kit and Speed stir
