Thread: Pool Issues - New Owner
    Feb 2016
    Collierville, TN
    16
    I am using the TFP method, and things are looking great. However, I have a leak somewhere. I am losing about 2 inches of water/week. I also have some air bubbles coming from one of my returns. Additionally, I went to turn the Polaris cleaner on this morning, the pump comes on but the cleaner does not move. Any help would be appreciated. I considered calling a local pool company to come take a look, but thought I would try here first. Any help is appreciated. Thanks.
    25,000-gal IG, vinyl, sand filter, Built in 2002, TF100,
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    Re: Pool Issues - New Owner
    If you are seeing air bubbles that should mean that you have a suction side leak, i.e. somewhere between the pool (skimmer, main drain) and the pump. If the leak were between the pump and the pool, aka pressure side leak, you would only lose water. Do you find that you lose more water when the pump is off? Try this article, generally leaks are above ground and accessible. I hope your's is. Pool School - Suction Side Air Leaks
    I can't help in the Polaris much, but if air made it to the Polaris that could stop it from operating. Good luck.
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    Apr 2016
    San Diego, CA
    115
    The air coming out if your returns means air is getting pulled into the lines somewhere. Since you have a leak, my guess is that this air is coming from the skimmer when the water level lowers. Do the bubbles stop when you top of the water level? I may be wrong but I'm guessing this is not the source of your leak but rather a symptom of it.
    As for the source of the leak, have you tried isolating different possible sources? Do you see moisture around any of the equipment or plumbing? If your automatic cleaner doesn't move it's probably not getting enough pressure/suction so I would start looking at things on the pressure side between the pump and the returns. It's your filter pressure reading normal?
    11,500 Gal Fiberglass IG Pool. Hayward cartridge filter with Pentair 3/4 HP pump
    500 Gal Fiberglass AG Spa with cartridge filter
    Taylor K-2006 test kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    A small amount of air bubbles from one return, usually the closest to the pump, is what saltwater chlorine generators do when they are making chlorine. Do you have one?
    Feb 2016
    Collierville, TN
    16
    The pool does is not salt water.
    the pressure gauge looks to be shot. It needs replacing, but I am not sure if the gauge can be replace, or if it requires more than that.
    I do not usually turn the pump off. I do not have timer, so I usually just let it run all the time. I will do some more investigating. I read where the gasket needs to be coated in silicon lube. Maybe that can be part of it.
    DFW, TX
    24,450
    Here are some nice gauges for 13 bucks, TFTestkits.net. The gauge should just unscrew and screw in the new one. But, that won't be the source of a suction leak. Suction leak is between the pool and the pump, see link fro Pool Tool above.
