Results 1 to 17 of 17
Thread: FC vs CYA Question
    Apr 2016
    Tyler, TX
    6
    FC vs CYA Question
    OK guys I have read through a lot of information here and have a question in regards to FC:
    I understand the TFPC chart of FC vs CYA and it makes a lot of sense, however, why is this not more readily available from other sources? I get confused as to why most test strip kits (I know they aren't accurate) and pool stores would tell you to maintain FC levels of 1-3ppm without regards to CYA levels? This would seem to be a bit short-sighted and cause major problems with pool water especially as CYA levels increase. I am 100% agreeing with the TFPC method and plan to follow this websites recommendation, so I am not doubting anything on TFP at all, this is more out of curiosity for my own mind LOL...
    22000gal IG plaster, Dallas, TX area (Feb 2016)
    Filter: Cartridge, Pentair
    Main pump: Pentair IntelliFlo VS (2HP)
    Boost pump: 3/4hp, Polaris cleaner
    klynch494's Avatar
    Aug 2015
    Twin Cities/MN
    96
    Re: FC vs CYA Question
    Just thinking out loud here... but maybe it has something to do with getting you back into the store to spend more money on their products that magically turn your water back to "crystal clear"...
    Kevin, TFP Believer & Supporter
    (Yup, I drank the pool water)
    13.5K gal, 24' Round AG Vinyl, TF-100 Test Kit
    2HP Waterway Pump, 200 SqFt Hayward Element Filter
    Recommendations: Pool School, TFTestkits & Pool Math
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,817
    One reason is that pool stores are in business to sell products with more markup than bleach and baking soda, etc. They are also primarily promoting the use of pucks to chlorinate, which constantly raises CYA (i.e. constantly changes the required FC). This concept would be impossible to effectively communicate to customers - many people don't want or care to know. Further, they may not really accept or buy into the theory behind the FC/CYA relationship. But mostly it's too hard for pool stores to quickly communicate those ideas to the masses and it's not a great business profit case. The philosophy here at TFP is understanding what you put into your pool and why. The philosophy of pool stores (and not a bad business concept really) is to have the customer put their faith in the pool store and be reliant on them to sell you what is needed. And then when you have "chlorine-lock", just drain 3/4 of the water and re-buy their chemicals to re-balance the water.
    I think it's great that you are curious, and that you found a great place to help you maintain your pool inexpensively and safely. Others may be able to lay out the Pool Store conundrum better than I.
    Feel free to continue to utilize the resources here and especially Pool School. Pool School. There is a graduation ceremony after you open your pool to clear water next spring!
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Apr 2016
    Tyler, TX
    6
    Thanks guys for the responses!
    It is funny after reading your responses and thinking back to last time I went into the pool store after they tested my water. I starting asking the guy helping me about the pucks and CYA levels and how to prevent CYA levels from rising. He kinda nodded his head and said that basically you just have to drain some water to get CYA level back down. He quickly moved the conversation along to all the different chemicals I need based off the testing they performed and I politely told him I would take those into consideration and left. I am not saying he was deliberately trying to deceive etc, but it does seem like a very good business model to have customers completely rely on your testing and recommendations to keep their pool looking great.
    Anyway, I have a lot more to learn here and have already learned enough to feel fairly confident about maintaining my pool. I will hopefully get my TF-100 test kit in today or tomorrow and may post up some numbers just to get feedback from all the experts here!
    Thanks!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,490
    Easy answer for me! What he ^^^^^^^^^^^ said!
    I LOVE that you are asking questions! You will learn SO much and THEN be able to help others!
    How I learned what I did was reading a section at a time. You will see someone with a problem and all of the ideas and answers to get it fixed.
    Kim
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    I wonder if anyone has had any warranty issues keeping FC at higher levels?
    The pool guy my pool builder sent told me I was at risk at damaging my equipment when he tested my FC at 4 - referencing the "industry standard" 1-3. We all know this isn't true, but is totally what they teach in CPO.
    Helpful Links: Pool Chemistry 101 - Recommended Levels - Recommended Chemicals - FC/CYA Chart - SLAM Instructions - Pool Math
    Test Kits:
    TF-100 - Taylor K2006 - SpeedStir Upgrade - Taylor K-1766 Salt Test
    My Pool:
    28k IG built May 2015 - Autopilot SWG - Pentair VS Pump/DE Filter/Heat Pump
    Jan 2014
    Buckeye AZ
    807
    from what I've seen here, the whole cya/FC relationship goes back to one research paper from the 70's, in conjunction with a bunch of user observations. Major industry is probably not going to make a major change without more research and lab results, and if nobody is doing that research, the "old standard" ways just continue.
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    Quote Originally Posted by BuckeyeChris View Post
    The strange part is that it isn't a major change. Its a 4ppm difference in recommended FC level at most.
    Test Kits:
    My Pool:
    Donldson's Avatar
    NW Ohio
    2,894
    Quote Originally Posted by pinguy View Post
    It is up to a pool owner to know the requirements for their warranty. There are some stories in the archives of owners being bound to certain ranges to keep their warranty valid, some even being required to submit occasional water samples to verify their compliance. Seeing how quickly some heaters have been destroyed by low pH I can understand the strictness of such requirements. In those cases the owner just has to work around it, by keeping their CYA low or other means of getting by with a low FC.
    I think BuckeyeChris has it, the standards are the standards and have been for something like 50 years. Most of the people in the industry don't follow the relationship not because they are afraid of losing money but because they don't even consider that they might be incorrect about something they have known their whole careers.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    JoyfulNoise's Avatar
    May 2015
    13,201
    This is an oldie but a goodie that covers this topic in some depth - blind faith and this forum?
    Chem geek's Post #32 is particularly informative - blind faith and this forum? - Page 2
    Matt
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    The EPA limits FC to 4ppm
    I suppose that sheds a bit of light on the 1-3 standard
    But it also begs the question...how are all these commercially run pools following 1-3 not having more issues with water quality? Low CYA and more frequent (several times per day) testing than a homeowner would do?
    Test Kits:
    My Pool:
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Define 'Free Chlorine'. It is the chlorine that is not bound by CYA. So in most TFP pools it is much less then 4. More like 1 or less. Right?
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    Quote Originally Posted by pabeader View Post
    I'd think so, but how would one test for only unbound chlorine?
    Test Kits:
    My Pool:
    May 2015
    13,201
    FC vs CYA Question
    FC is defined as the sum of active chlorine (HOCl/OCl-) and chlorinated cyanurate (chlorine bound to CYA). That is what the test measures and that is what the industry defines FC as.
    Matt
    Jan 2014
    Buckeye AZ
    807
    you'd need to take your FC and do the math with your CYA. chem geeks old posts may have a table in them somewhere, but there's not a test for "Unbound" chlorine.
    Outdoor commercial pools have a much higher demand and have more robust chlorination methods, in addition to other sanitizing methods that are overkill for a residential pool. They are required to test throughout the day. If you are testing a lot, and only using OTO tests, then I suppose it also makes sense to have your FC target in the 1-4 range so you can use that test.
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    But that calculation is based off the science the pool industry is not accepting, which lands us back at square one.
    Literally by that definition, it's impossible to recommended a FC level without knowing CYA. Madness.
    Test Kits:
    My Pool:
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Agreed. Ask anyone here what level to set your FC and we will always ask what your CYA level is and show you the Chlorine CYA Chart
