Results 1 to 11 of 11
Thread: mold on pool decking
    Houston, TX
    1,107
    Hello to all,
    On approx. 1275 sqft of pecan-colored tumbled travertine [non-sealed], pool decking pavers in the Versailles pattern, the polymeric sand btw the travertine pavers is now black and moldy. This was installed in Nov 2014, pool water filled later Feb 2015.
    What product and/or process is there to get this back to the original colored [off white/light gray]? Also, some of the tumbled travertine pavers where there are natural pits, also have mold in them too. Suggestions to clean these areas? Also, there are some area's where the pavers intersect and if all four intersecting pavers have a depression, then there might be a pit the size of a nickel to quarter as the largest...most are size of a pea.
    Finally, is there anything I can do to prevent or slow-down the future molding process? The widest areas are maybe 1/8" and a but wider where the travertine butts up to the foundation.
    Thank you and pls let me know if you have any questions?
    regards, tstex
    InGround 15K gal, 18'x30' 3.5' to 5.5' depth w/ 9'x9' spillover Spa, Pebblesheen w/ Travertine, Hayward 3 HP VSP, Hayward C4030 Cartridge, Hayward 1.5 HP for 2 Scupper columns, ProLogic, PL-PS-8 Panel, Hayward H400FD 400K BTU Heater, 3 ColorLogic LED, Spa Blower, TF-100 w S-Stick, QC Tiger Shark, Autofill If you enjoyed your TFP experience, please consider donating to Support TFP!
    Jan 2012
    'burbs of Augusta, Georgia
    7,373
    Re: mold on pool decking
    Have you tried washing the deck down with a diluted bleach solution?
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    Can you pressure wash? I have to pressure wash my concrete decking every spring.
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
    Aug 2015
    PA
    74
    I have had great luck with this product. I use it on my siding, concrete walkways, and hardwood deck.
    http://www.amazon.com/Wet-Forget-105.../dp/B0019KSUG6
    Ryan
    New salt diving pool started in February 2016. Approximately 42x20 kidney shape. 100 sq/ft tanning shelf. White Plaster. 2 Pentair 5g Color LEDs and 1 Color Globrite LED. All Pentair equipment. DE filter. Kreepy Krauly 820 robotic cleaner. EZ touch wireless system. 860 sq/ft Techo-Bloc paver patio with matching fire-pit.
    Houston, TX
    1,107
    Thank you for your feedback.
    I have not tried using diluted bleach. This is a soft tumbled travertine and most caution no using anything caustic.
    Power washing runs the risk of blowing out the softer material from the natural travertine depressions...there's a long story to this w the orig PB's sub's that is not good.
    I looked at the link of the product. It states "Wet & Forget". Most products to work really well, they're applied, then "something" is used to agitate the surface to remove stuck debris and other...in this instance, it could be a soft bristle broom, but usually something is needed. How do you use it Ryan?
    Thank you folks, tstexx
    Aug 2015
    PA
    74
    When using on my siding I just spray it on any mold/mildew, usually it dies within a few days and then over month the usual rain fall wash it off.
    My deck is a little different. I use it prior to staining, so I will spray it on, wait a few days then use a power washer to clean everything off. I am sure the mold/mildew would eventually come off on its own (with rain), but with staining I want/need a totally clean and uniform surface in a short period of time.
    Concrete front walkway I will spray it on, wait a week or two and then hit any stubborn areas with water and a soft bristle brush to break anything remaining loose.
    Houston, TX
    1,107
    Thanks Ryan - Sounds like you have each application down based on your needs and uses...I did not delve into the directions, but do you dilute it to X % of water, then use a handpump sprayer to apply?
    NOTE: just saw it's 6:1 dilution rate
    Aug 2015
    PA
    74
    Correct, I just use a typical pump sprayer you buy at the big box stores and dilute it as directed with tap water. Any left over just lives in my shed until next application.
    Houston, TX
    1,107
    Thank you for the clarification.
    It seems like once it's sprayed on, it's supposed to be able to soak in, stay in contact for X days, then be wetted by rains & gradullay washed off.,,the residual time seems to be part of the cleaning process. We are having so much rain, that maybe I need to wait. Any experience that you feel wks better? Thanks again.
    Aug 2015
    PA
    74
    It has been awhile since I used it (last summer). From memory I try spraying on when no rain is in the forecast for a least a day. That will kill just about anything I needed killing. Worst case I hit the bad spots again a week or two later.
    Ryan
    Houston, TX
    1,107
    Thank you Ryan.. I'll give it a try.. Unlike that it has no acids, bleach or other..
