Thread: Cheap, Temparary Vac for IG pool
    Apr 2016
    South East USA
    78
    Hi,
    My in-floor cleaning system is resting while I wait another week or so for some parts to come in the mail.
    I do have some debris in the deep end (mostly introduced by my spaniels), plus some pollen residue. It's not a lot but I'd like to vac it up rather than wait for the parts for the cleaner.
    I have never vacuumed the pool before because of the in-floor system.
    Is there an inexpensive vac from either Walmart of the small lps you can recommend?
    I do have a hose and a pole already - perhaps i should just send a child in with the hose?
    ft.
    ~22,000 gallons, freeform, Pebbletec, beach entry AquaRite SWCG v1.33 Hayward Tristar SP325EE pump for main draw & skimmer Hayward sand filter S310S 1.5 hp booster pump Paramount PCC2000 in-floor cleaner, skimmer, debris containment canister Waterfall Pentair Intellibrite 5g LED light in Pentair stainless wet niche Jandy Lite2 heater: removed Auto-fill: deactivated
    Re: Cheap, Temparary Vac for IG pool
    Geebot
    Chicago, IL
    30K gal, InGround Plaster Finish, 3.5'-9.5', Maytronics S300 Cleaner
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,002
    If the hose fits into the skimmer and you already have a pole, just go to Lowes or Home Depot or even the <gasp> pool store and pick up a head for twenty bucks.
