Results 1 to 7 of 7
Thread: Power a pump using solar panels
    Dec 2014
    Belle River, Ontario
    18
    I have a Hayward Super Pump (I believe it is .75 HP but might be 1hp). Has anyone ever hooked up their pool pump to be run solely on Solar power during the day (and be dormant at night).
    What size panels would be needed and what size inverter
    38,546
    Re: Power a pump using solar panels
    I believe this has been discussed before and bottom line is that it is not practically feasible.
    The only way it might make sense is if the motor could run directly on the 12V from the solar panels, which pool pumps can not.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    If you google about that a few things come up.
    It requires a completely different motor for one. Reliability was questionable last I looked.
    Dolphin E10 Cleaning Robot.
    Dec 2014
    18
    thanks for the replies guys..
    With energy prices in Ontario going up again (every six months we get an increase) I was looking for ways to save.
    The rates will be
    13.2 cents kWh from 7am - 11am
    18 cents kWh from 11am - 5pm
    13.2 cents kWh from 5pm - 7pm
    8.7 cents kWh from 7pm to 7am
    (plus delivery and regulatory fees on top of this).
    I heard it is better for the pool water quality to run the pump during the daylight hours, so that means some of the most expensive times.
    38,546
    You heard wrong. No issue running it for just a few hours between 7pm and 7am.
    In fact I think we say that in the Determine Pump Run Time article.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    As mentioned above this takes either a special DC pump motor, or much more elaborate whole house solar electric system, and while there are some out there, the cost makes them not practical, also the only model I know of is from Europe and uses metric pipe fittings.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Well, it sounds like you would do very well with a vs pump to save money.
    And as others said you don't need to run the pump very long at all.
    I have a single speed 1.5 hp but only run it three hours a day total (for skimming)
    The only additional time I would use is 2 more (5 hours total) on sat-sun for heating, if needed.
    It's been plenty to keep the water nice.
