Thread: Come down off slam
    Apr 2016
    Murfreesboro, TN (Middle TN)
    103
    Come down off slam
    Hey guys, successful slam, just coming back down to target fc of 5. I went ahead and ran full tests and I'd like to get some help on adjusting ta/ch if you think it's necessary.
    FCL 7
    CCL .5
    CYA 50
    Ph 7.6
    Ta 140
    Ch 150
    Thought?
    Also pictures below, thanks for all your help!
    Before
    After
    27' above ground, 17500 gallons, Cartridge filter Hayward SW1000z4, A.O. Smith Pump SP1515Z1BC 70 GPM, Test kit Taylor TF-100
    Murfreesboro, TN
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    Re: Come down off slam
    Nice job, looks great! You can't adjust the CH without dumping water and you have a vinyl pool so you can pretty much disregard that one. No need to worry about it.
    As for the TA, adjustment will only be required if your pH rises quickly. In that case, just use MA to lower it and the TA will drop each time you add acid. Your pool will seek it's own TA balance as you adjust the pH.
    Time for a swim...if its warm enough!
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    Everything looks good. You don't need to worry about the CH with Vinyl. TA is fine as well, no need to adjust unless you have problems keeping your pH balanced.
    Helpful Links: Pool Chemistry 101 - Recommended Levels - Recommended Chemicals - FC/CYA Chart - SLAM Instructions - Pool Math
    Test Kits:
    TF-100 - Taylor K2006 - SpeedStir Upgrade - Taylor K-1766 Salt Test
    My Pool:
    28k IG built May 2015 - Autopilot SWG - Pentair VS Pump/DE Filter/Heat Pump
    Apr 2016
    103
    OK great! Once you plug in all the values to the saturation wheel that came with my kit it says my water is in danger of becoming cloudy or developing scale which is why I asked.
    If it weren't for the dang wind we'd be set!
    Murfreesboro, TN
    38,403
    Forget the wheel, use PoolMath.
    Your water has a near neutral CSI, so there is no chance of scaling or randomly going cloudy.
    Apr 2016
    103
    Duly noted thanks all!
    Murfreesboro, TN
