Thread: Water Problem
    Mar 2016
    Fort Mill/SC
    41
    Water Problem
    So I thought for awhile I've had my water pretty well balanced, my pool's been sitting around 66-70, but the last week it's warmed up a bit now at about 76 when testing today. Salt ppm may have gone done and TA and CH maybe up, so wondering if these numbers look ok after a week of basically not doing much at all. I have a few chlorine tablets left in my tube that I've been trying to finish up so I expected the FC to be a bit high.
    FC 9.5
    PH 7.6
    TA 80 turned it very lightly, so maybe its really 85
    CH 330
    CYA 70
    Salt readings really low about 3100, it was at 3500-3600 last week using a meter thing, today I tested it was 2700, but the longer I let it sit in the water it just kept rising and rising till about 3100, then it rose much slower. I've been running our swg about 3 hours a day, no one swimming, no rain recently and no new fill water. I have a "pebbletec" pool, I guessed it to be about 13000 gallons and added about 400 lbs of salt about a week ago...
    anything here concerning?
    2010 In Ground ~ 12-15,000 Gallon estimated
    ~3 ft shallow ~ 6 ft deep ~38 ft x 17 ft Freeform shape Pebbletec Finish
    2 Drains, 2 Skimmers, Sidewall Vacuum (Not in Use)
    Dolphin Oasis Z5 - PHPF1.0 Pump - Jandy CV340 Filter
    Fort Mill, SC
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    Re: Water Problem
    I would say everything looks fine. As for the salt, the test's accuracy is +- 200ppm at best. That means two identical tests could be "off" by 400 ppm and still be considered perfectly accurate. I would stick with one type of test and if strips there is a precise time to leave it in the water, if memory serves 30 seconds then remove and then read result. The packaging should have the dip duration. As long as the cell is producing, you are good. As for running both the cell and tabs, I dont see a reason. Maybe you could save the tabs when you need a little CYA bump or when the cell poops out.
    Good luck!
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    lefty51's Avatar
    May 2015
    East of Royals country western MO
    451
    Re: Water Problem
    I agree, remember those tabs will raise your CYA so be prudent with using them as the only way to lower CYA is with water replacement
    Si -central Mo. 32' x 16' -- 3'4" to 6' deep Vinyl liner - 16,500 Gals : Triton II filter -Duraglass 2 hp pump - 1 speed : SI-30 salt generator
    TF-100 with speedstir
    Mar 2016
    Fort Mill/SC
    41
    Re: Water Problem
    Quote Originally Posted by lefty51 View Post
    definitely will keep an eye on it, i think there's only 1.5 or 2.5 tabs left in the thing, so I dont suspect it will be a problem, especially since im on the lower end of 70.
    Fort Mill, SC
    lefty51's Avatar
    May 2015
    451
    Re: Water Problem
    Quote Originally Posted by Ejkeebler View Post
    Good deal, your on track. I am curious, does your SWG have a salt reading on it? Mine does and I compare it to my K-1766 test kit. the two readings don't always match but the two give me a reading I am confident with
    Mar 2016
    Fort Mill/SC
    41
    Re: Water Problem
    Unfortunately the circupool sj40 has nothing of the sort. Will only flash if it's low.
    Fort Mill, SC
