Results 1 to 7 of 7
Thread: Question on adding salt.
    Apr 2016
    Lambertville, mi
    4
    Is the only benefit of adding salt to a pool without a SWG to make the water softer? Other question do you have to use a different test kit if salt is present in the pool? How much do you add in a pool 25k without a SWG?
    Thanks
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Question on adding salt.
    Welcome to the Forum,
    Salt makes the water "feel softer" but it doesn't actually soften it by doing anything to the hardness. Same kit, and our Pool Math calculator at the top of the page will tell you how much to add. Shoot for about 3500-4000 PPM to get the same effect for feel in a SWG pool.
    Essential Links:
    Jun 2011
    Long Beach, CA
    2,790
    Welcome to TFP!
    I'd suggest trying the salt level at around 2000 before going all the way to 3500. You will be adding salt as you chlorinate with other methods other than using a SWG.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I'm sorry, I stand corrected, we do suggest 2000 for this purpose, and I was mistaken.
    Essential Links:
    Apr 2016
    Lambertville, mi
    4
    Quote Originally Posted by Patrick_B View Post
    So it does nothing in regards to helping with Algae or anything else?
    Saturn94's Avatar
    Mar 2015
    Virginia
    501
    I've found my salt pool much easier on my eyes than non-salt pools.
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 with booster pump/Hayward Superpump 1 hp/city water/pool installed March 2004
    38,548
    Quote Originally Posted by wgregww View Post
    Not really ... just for feel.
