Thread: Ortega check valve shot
    My pool is 8 years old and i've replaced a lot of parts this spring. Stumped on what to replace the Ortega spring check in the spa return line with. The obvious choice seemed to be a Jandy 90 deg. spring check except it's not recommended for the flow direction. I have room to mount a straight connection vertically but once again Jandy shows flow down installation as a "wrong" on their installation instructions. Without this check my spa drains overnight enough to expose the plaster. I did install a new spring and seat but the body itself is worn so it won't seal with out a lot if silicon grease. Any ideas.
    Thanks
    Hugh
    10K gal, Colored Plaster, 2 HP Pentair Whisperflo pump, Pentair Quad DE filter, Paramount in-floor cleaning system w/2HP Pentair Whisperflo pump.
    38,322
    Re: Ortega check valve shot
    You can install the Jandy check valves vertically, I am not sure why they suggest you can not. Although if the correct flow direction is down, I suppose it may not seal as well since the flapper would need to be pushed up.
    Although it will look goofy I could turn it up then down so there will always be a little head pressure. Too bad I didn't know any better when I built the pool and let the contractor install all plumbing without unions.
    Thanks for the reply,
    Hugh
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    They have springs in them to keep it shut. Jandy Spring Check Valve 7305. Jandy 7305. Zodiac 7305.
