Thread: Caclium and scaling and csi
    Aug 2014
    NJ
    435
    I added Calcium Chloride because my 2015 TFT test kit said my CH was 225. But after adding I tested with my new 2016 TFT test kit and it was 425 (even though Pool Math said it should go to 325). I then retested with my 2015 test kit and it read 325. I am assuming the 2016 test kit is right but should I get a third opinion? I kept my 2015 kit on a table in our sun room (with a lot of windows) over the winter. It gets colder there then the rest of the house in the winter, but that room still gets heat, and gets a little hotter in the summer because of all the windows.
    If the 425 reading is correct, I am concerned that I could get scaling if my PH rises too much. My pool is one year old and gets a lot of aeration. Will scaling result only if my CSI number falls out of the acceptable range or could a high PH and 425 CH cause it no matter what. My CH did not rise last year at all except when I added calcium chloride, so I was hoping to not have to worry about it, but am now concerned it may be a problem because it is on the high side now and my Polaris seemed to be picking up calcium (looked like crushed snow) when I opened this year (although my CH was not rising at all according to my 2015 test kit).
    Thanks
    p.s My CYA is 30 and my TA is 60
    1200 Sq Ft 41,000 Gal. Gunite, JANDY SVRS VS pump, JANDY JXI 400,000 BTU, Polaris 280 w/ 3/4 BP, Rockwall and Grotto (w/6 jets and blower), 2 JANDY Lam Jets, 2 LED Bubblers, 5 Ledlights, AQUALINK P16 RS, 90% Quartz, SWF 185 GMP BP, SWF 125 BP, Levelor K1100 Autofill, AP Digital SWG, 2 skim and 5 returns, and mostly 3 inch piping
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Caclium and scaling and csi
    Keeping your CSI on the negative side will prevent scaling, -0.1 to -0.2. This will work even with CH over 1000 ppm. The highest number I've seen here is 1200 ppm.
    I don't know about the potential testing questions.
    More here
    Pool School - Calcium Scaling
    and here
    Langelier and Calcite Saturation Indices (LSI and CSI)
