Results 1 to 8 of 8
Thread: Barrel for Chlorine
    Mar 2013
    CT
    351
    Barrel for Chlorine
    Is there any special specs I would need for a barrel to hold chlorine?
    Does it need to be made of any special material?
    I was thinking of going w this one...would this work??
    http://http://www.uline.com/Product/Detail/S-19418/Drums/Plastic-Drum-15-Gallon-Closed-Top-Natural
    16 x 32 In-Ground vinyl, 21,000 Gallons, Hayward Cartridge Filter, Hayward Tiger Shark robotic cleaner, Taylor K-2006 Test Kit
    JayG's Avatar
    Aug 2015
    Harrison, NY
    204
    Re: Barrel for Chlorine
    HDPE works.
    Jay--Metro NYC
    35K gal, in-ground, free-form, pebble finish, 2 skimmers, 3 returns, autofill. No spa, no features. Partial shade.
    Pentair C&C cartridge filter (400 sq in), Pentair VS pump, Pentair 140 btu heat pump, Triton Plus Robo-cleaner; Stenner with 55 gal bleach cistern. TFT 100 test kit.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,111
    What are planning to do with it? Chlorine loses it's strength over time and if you are storing it outdoors, it gets even worse.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Mar 2013
    CT
    351
    FauxQ - Is this HDPE?
    pabeader - It will be stored in the basement. I want it clear to see the level of bleach.
    My pump and timer will be mounted on the side of my house. The barrel will be in the basement right on the other side of the exterior wall where the pump/timer will be.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,111
    Neat idea. At least it will be climate controlled. Still keep in mind about the loss of strength over time though.
    JayG's Avatar
    Aug 2015
    Harrison, NY
    204
    Quote Originally Posted by dschribs View Post
    Probably. I would call to double check just the same. Good luck,
    Jay
    Jay--Metro NYC
    Mar 2015
    Sugar Land , TX
    424
    It is HDPE according to specs on website. Looks like mine
    8500 gallon IG Pebble Sheen with Spa. 3hp Pentair VS Intelliflo ( pool ), 3/4 hp WhisperFlo ( water feature ),Pentair Racer, 400K Pentair heater, Pentair 500sqft Cartridge filter, EasyTouch 8, Stenner 45mp2 15gallon wired to ET8
    poolnewbies5874's Avatar
    Aug 2015
    SW Ohio
    124
    We are going to do the same thing! (placing barrel in basement for controlled climate)
    12,000 gallon Blue Hawaiian 'Hamilton' fiberglass IG 15x34 freeform, Pebble Beach finish, Pentair Clean & Clear 100 filter cartridge, Pentair SuperFlo 1.5HP pump, Stenner pump, Raypak 266k heater
    8/2015 pool build photos TFT-100 test kit
