Thread: Pump not working again suspect bad temp control
    mellenw's Avatar
    Jun 2011
    Dallas, TX
    24
    Pump not working suspect bad temp control. See picture of Penn A19AAF temp control and timer setup. Basic setup..Timer has a toggle switch at bottom that I flip to change speeds on pump (slow during normal operation fast for vacuuming).
    I (or rather my electrician friend) installed timer, and new pump about a year ago. The pump quit and tripped the breaker in November. Close examination showed a wire had arced between timer and temp controller so we replaced wires and toggle switch circuit and the pump worked normally.
    Now the pump stopped working but did not trip the breaker. This is becoming a chronic problem. Seems to be rain related but does not happen every time it rains.
    Electrician friend is out of town for a week so trying to diagnose and line up parts if need. My instinct says replace the temp switch because it is at least 10 years old and made in USA. I think Johnson stopped making them in USA 20 years ago.
    What advice can someone out there in TFP land give me? Penn A19AAFs seem to be hard to get. Can someone suggest a substitute?
    16 K gallon, IG, Concrete pool built approx 1970. (Resurfaced with plaster May 2015) 9 ' deep approx 17'x 33'. (1) skimmer, (1) bottom drain, (2) jets. PUMP: Hayward Max-Flo XL 2 speed 1 HP (installed May 2015). Sta-Rite T240BP-1 Crystal-Flo sand filter (installed 2007), Pentair 320 in-line chlorine /bromine feeder (2007 & 2012). TFPC with Borax/Bromine. taylor K2006 test kit. Mellen, Dallas TX
    ColdAirGuy's Avatar
    California
    85
    Re: Pump not working again suspect bad temp control
    I'm not really sure what the purpose for the stat is in your situation. I do refrigeration and use these all the time
    L36-931 | Johnson Controls | A19ABC-24C | Johnstone Supply
    If you suspect this stat as being your problem, why not just jump it out and see if it corrects your timer/pump issue?
    Anthony 16,000 Gallon Oval, White plaster, 30' Long 15' Wide 5 1/2' Deep end 3 1/2' shallow end.
    Pentair Intelliflo, FNS Plus 60sf. DE, Pentair Intellibrite 5G
    TF100 Testkit
    mellenw's Avatar
    Jun 2011
    Dallas, TX
    24
    Pool pump motor is cooked. 14 months old. Time to call Hawayrd and see how they handle the problem.
