Results 1 to 7 of 7
Thread: SLAMMING, CYA and chlorine tabs
    Apr 2009
    SC
    26
    I've been following the SLAM method for deswampifying my pool (I can only hope that my lawn will be as green as my pool was before I started!) and after 4 days it's coming around nicely. My question is that I didn't put any CYA in the pool first as I would be backwashing often. Instead, I put chlorine tabs in the skimmers to (theoretically) help keep the FC level up and to add CYA to the pool. After the pool is clear, I plan to add CYA to get the level up. My current numbers are:
    pH 7.2
    FC 16 (I've been keeping it between 16 and 20)
    CYA 0
    TA 90
    Is my plan OK or flawed? What changes should I make while the SLAM is in progress? Also, which is better: use my SWG to keep the FC at shock level vs continuing to use the di-chlor tabs (then add CYA after all backwashing is done) vs just keep adding liquid chlorine 10% until the pool is clear? Thanks for all the help and btw, the Powerwashing the Filtersand article was THE answer as to why my first SLAM failed. THANKS AGAIN!!
    43,500 gal/Heyward 240 sand filter w/ 1hp pump/In-Ground pool/vinyl liner/Jandy SWG
    38,290
    Re: SLAMMING, CYA and chlorine tabs
    That FC is too high if you have no CYA.
    You can add CYA in a sockand hang it by the return jet, then you will not lose much to backwashing.
    Tablets are Trichlor, not dichlor. They will not get your CYA up quickly enough.
    You can use the SWG if you like to maintain the FC. We recommend against it so you can monitor the FC loss.
    Apr 2009
    SC
    26
    Thanks for the reply. I looked at the CYA/Chlorine chart and it only goes down to a CYA level of 20. What would you suggest as a SLAM FC? My overnight FC loss test is stable at 16.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,493
    We're not fans of pucks in skimmers, it is better to put them in a floater.
    Jan 2012
    'burbs of Augusta, Georgia
    7,345
    Pucks in the skimmer basket cause a very acidic bolus of water to hit the pump when the pump is then turned on. Can be damaging to gaskets and such.
    38,290
    I would not go over a FC of 10ppm if the CYA is less than 20ppm.
    Especially since you have a vinyl pool that can be damaged by excessively high FC levels above the recommended levels.
    Apr 2009
    SC
    26
    Thanks to all! I will put all advice into practice today
