Thread: PDA not showing pool/spa temp, Jandy heater not working
    Apr 2016
    Phoenix,AZ
    1
    Unhappy PDA not showing pool/spa temp, Jandy heater not working
    Hi, my Jandy PDA is showing only air temp but not showing Pool/Spa temp, instead is showing -- two dashes. The Jandy LXi 400 heater shows both air and pool/spa temp but the heater will not turn on. I replaced the temp sensor that's attached to the heater (Zodiac R0456500) but still having the same problem.
    I've had the pool for eight years and I've replaced the temp sensor about 3 years ago (temp was off but no --) but the fix is not working this time. Can anyone help???
    Sep 2013
    Charleston, SC
    537
    Re: PDA not showing pool/spa temp, Jandy heater not working
    5900 G Fiberglass IG pool (circa 1990), SWG Hayward Aqua Rite GoldLine (2013), IntelliFlo Variable Speed Pump (2013), Hayward Pro Sand Filter (circa 1990), Well water (no iron or other metals fortunately), test with Taylor K2006C, Charleston, SC
    Oct 2016
    Austin/Texas
    1
    I'm having the same problem. I also replaced the temperature sensor with the same model Zodiac R045600 but the problem persists.
    If I disable the TSTAT remote on the heater itself it works fine manually.
    I just do not understand why the water termperature on the Jandy PDA remote will not display.
    Did you find a resolution to this problem ?
    Jun 2017
    Saugerties, NY
    2
    My Zodiac heater is not working. We replaced many parts. Display panel is blank. Any ideas on what could be wrong?
    16x32 in ground pool; 17,500 gallons
    hayward 2 speed pump
    Aqua rite chlorine generator
    Zodiac LXi 400p heater
