Thread: Newbie alert! - Pump recommendations
    Apr 2016
    Dawson, AL
    2
    Hello! I'm new here to TFP (well, new to everything pool related &#128541 and this is my first post so bear with me.
    I have a 16' x 48" Coleman with a 1500 gph pump (also Intex 7000 SWG). I have a Heritage thru wall skimmer (wide mouth) ready to install.
    My first concern is that my pump won't be powerful enough for the skimmer to be effective enough to make a difference. Being able to vacuum from the skimmer would be awesome as well. Any suggestions? I'd hate to install the skimmer and it be useless. I also don't want to spend a fortune on a new pump, but I am interested in a sand filter pump. I've looked at Intex, but I'm concerned about the fittings and don't have a clue how to remedy that.
    On a similar note, where should I place the skimmer for maximum efficiency?
    Second, I'd like to hard line my system. Tips, warnings, experiences, etc. would be greatly appreciated!
    I'm running my pump 24/7 only because it seems like a good idea. SWG runs 7 hours in the evening. Water is clear expect for the constant layer of pollen on top (spring time in Alabama...lovely). My test results using my TF100 were all within suggested ranges. Awesome kit btw!!
    If y'all think my pool system would benefit from a different pump, I'd like to go ahead and get one ordered so that I can hard line and install everything so that I can enjoy a trouble free pool fun summer! Thanks
    Joy in Dawson, AL (Northeast AL)
    5,145 gallon Coleman Power Steel Frame AG, Flowclear Cartridge Pump (1,500 gph) {lame...I know} :((
    Intex SWG (7,000 gallon)
    Coming Soon: Heritage WideMouth Skimmer, TF100 (currently using strips)
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    Re: Newbie alert! - Pump recommendations
    Hi, welcome to TFP! If at all possible, orient the skimmer so prevailing winds will blow debris toward it. That way your pump is not fighting the affects of the wind. It should also be as close to the source of power as possible. Here are some intex threads that can give you more ideas about making modifications to your pool. Useful links for fellow Intex Pool Owners
    Love TFP? Become a
    TFP Supporter!
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Welcome to TFP
    I used an in ground pump and filter and also did hard pipe for everything, I went overboard but that is kind of my thing check out my build thread, you can use the same equipment if you want..
    For what I think your looking for, a 2 speed pump and sand filter would work great.. here are a couple suggestions you could look at..
    Amazon.com : Pentair 347990 OptiFlo Vertical Discharge Aboveground Pool Pump with 2 Speed Motor and Standard Plug, 1 HP : Swimming Pool Water Pumps : Patio, Lawn Garden
    Amazon.com : Hayward S180T Pro Series 18-Inch Top-Mount Pool Sand Filter : Swimming Pool Sand Filters : Patio, Lawn Garden
    Here is an all in one filter and pump that may work perfect for your size pool I love 2 speed pumps but this smaller pump should work also...
    Amazon.com : Hayward VL40T32 VL Series Top-Mount Sand Filter System : Swimming Pool Sand Filters : Patio, Lawn Garden
    Apr 2016
    Dawson, AL
    2
    Thanks for the suggestions! I'll do some more research and choose one that I think will fit the budget and needs. And the skimmer location should work well. I'm planning a trip to lowes this afternoon after work to pick up some PVC to start my hard line project at least for the skimmer. I also saw a post where someone used their old filter for a fountain, so I'm borrowing that idea also!
