Results 1 to 8 of 8
Thread: Swimming/Shocking (Test #'s added 5/8)
    My kids are dying to get in the pool!!! I've kept them out while I've been shocking for 2 reasons:
    1-I figured the chlorine level was too high to comfortably swim, and
    2-If I'm trying to kill 'yukky stuff', kids just add more 'yukky stuff' (and I have 5 of them!!), so I'd be slowing down the process.
    Is my thinking correct? And if it is, when is it good for them to get in?
    Sunny SW Florida! Uncaged Free-form IG pool, Pebble-tec finish, 20,000 gallons?? (Beach entry/tanning ledge is 9' x 9'; it's free form 37' x 19'. Depth 3 feet to max 5.5 feet. There's also an attached spa with spillover: 6 foot radius. Anything else?)
    Prologic computerized thingie with SWG; 1.5 hp Hayward II Super pump, cartridge (i think) filter. (Hubby contracted the whole thing...so I don't have a detailed list on what we've got!)
    Feb 2008
    Denton, TX
    5,061
    Re: Swimming/Shocking
    As long the the chlorine level is below the shock level for your CYA, it is generally thought of as safe to get in.
    As for the yucky stuff, I would think that as long as your CC is < 0.5, it is probably safe from a sanitation perspective.
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by 257WbyMag
    I agree.
    You're done SLAMing when:
    OK, thanks...but i haven't gotten to that point where my FC isn't dropping overnight. So technically, my FC SHOULD be at shock level...right???
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Quote Originally Posted by graffster
    Right.
    OK...I think I'm done 'shocking'! Here are my new numbers:
    FC 6
    CC 0
    TC 6
    pH 7.8
    CYA 40 (Just added powder form 48 hours ago to raise it from 0)
    TA 160
    CH 160
    Salt 3000
    pool temp 85
    Will that CYA probably increase because it's such a "new" addition? Does everything else look ok? (I'm never sure what to adjust, and when!!)
    Pool looks really good...just want to keep it like that!!!
    Re: Swimming/Shocking (Test #'s added 5/8)
    Unless your PebbleTec is less than 8 weeks old, you want to raise your CH level to at least 250. It is probably also time to lower your PH down to 7.5. Other than that you are looking good.
    That's all thanks to you folks here at TFP!!! Thank you, thank you, thank you!!!!
