Results 1 to 8 of 8
Thread: Adding a pump timer
    Apr 2016
    SW Michigan
    6
    Adding a pump timer
    Hi,
    First of all new to pool ownership and new to this forum so please excuse my lack of knowledge on pool equipment.
    I am looking to add a timer to my pump. My current switch for my pump is pictured below . How would I go about adding a timer and what is a good recommendation on a timer.
    Thanks in advance.
    38,457
    Re: Adding a pump timer
    Welcome to TFP!!!
    I would suggest a mechanical Intermatic, the T101B or T101P ... assuming your power is 120V, given the switch.
    You should be able to just remove that switch box, install the conduit into the timer, and wire it up according to the instructions.
    Jan 2012
    'burbs of Augusta, Georgia
    7,367
    I love my Intermatic timers. I'm not one for fancy schmancy high tech stuff. This is a simple and convenient way to be able to set the timer to come on daily at x hour, off at y hour, and a fast flip of the override switch turns it on/off at whim.
    http://waterheatertimer.org/images/I...10101R-200.jpg
    Jun 2012
    western NY
    1,562
    As Jason recommended the intermatic is the best and simplest way to go. However, seeing the one single conduit coming from the bottom of the box this may be a switch leg circuit that probably will not have an available neutral wire in it to allow full time power to the timer. If you could open up that switch box and get a picture of the wiring inside it we could verify if it can be done or not. It is possible that the feed for that box comes in from the back side (best situation) which would allow for the timer to be connected.
    Dan
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    38,457
    Thanks Dan. I overlooked that possibility.
    Apr 2016
    SW Michigan
    6
    help with wiring pump timer
    Merged by moderator. jblizzle
    Trying to set up my pump timer, Where do I plug these wires timer is a t101p
    Thanks in advance
    20,000 gallon Vinyl Lined, Sand Filter, In ground
    38,457
    Re: help with wiring pump timer
    Um, no one can possibly help with just the information provided.
    You need to know which set of wires is coming from your power supply and which set of wires go to the motor.
    Then put the black wire from the supply on terminal 1, the black wire to the motor on terminal 2, and both white (neutrals) to terminal A, and both ground wires to the ground screw ... just like the diagram shows.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    If the diagram doesn't tell you everything you need to know to wire it, perhaps you should have someone else doing it. It's really pretty simple, but if you don't know what you are doing, electrical work isn't very forgiving of mistakes.
    chiefwej
