Thread: Analysis Paralysis.....Pool Robot Newbie
    Apr 2015
    Boston MA
    95
    Hi everyone,
    I really need your help in selecting a pool robot.
    I'm absolutely new! I've read and re-read everything there is to know about pool robot options...and I'm tired .
    It truly is a lot to digest-though a few things I'd like to share about our new pool.
    1. It's a hybrid pool-half in/half out.
    2. It's has a vinyl liner
    3. It is a SWG...if that means anything prior to selecting the robot?
    4. It has 90 degree walls in the shallow end
    5. It has a small incline in the deep end to the 4ft wall section
    6. It has steps (which I understand may/will need to be cleaned manually-no problem).
    7. Sorry for the long winded post.
    Lastly, I'm open to anything as far as a manufacturer. I'm slightly drawn towards the Dolphin/Maytronics line, only because of the reliability and performance reviews I've read online.
    Thank you in advance everyone.....here's to our first ever summer with a pool with our family.
    15x30 Oval 13,500 Gal, IG Vinyl built Fall 2015,
    TF-100 test kit
    Pentair Sand Dollar 40 Pump & Filter System 1HP Dynamo
    Pentair Intellichlor SWG, Dolphin Nautilus
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Analysis Paralysis.....Pool Robot Newbie
    SWG has no bearing on a Robot, and you mean half indoor/outdoor? No matter either way if so. I'm a Dolphin fan myself so I am biased there. My friend got the same model for his 90 degree non radius end comers, vinyl pool, and it's been flawless. No cleaners I'm aware of do much on steps. Good luck, and let us know what you decide.
    Essential Links:
    Apr 2015
    Boston MA
    95
    Quote Originally Posted by Patrick_B View Post
    Which Dolphin did they purchase? Thanks for the info
    TF-100 test kit
