Leak in plastic can I caulk ?
I just fixed a issue similar to yours. I blew out the line first and then added suction with my shop vac. Once under suction I laid on the glue to the outside of the pipe and it worked beautifully
Sent from my SM-N910V using Tapatalk
PVC glue? By itself, I don't think that will hold for very long. Normally, you have to mix it with PVC pipe shavings so it will bond properly but on it's own, it won't bond properly.
