Results 1 to 9 of 9
Thread: Leak in plastic can I caulk ?
    20160426_191208.jpgI have a small leak in the black plastic part where the arrow is. Can I use caulk or something to stop the leak? I unscrewed everything temporarily for the picture
    25k Gallon Gunite Inground Pool
    Pentair FNS PLUS DE filter
    Pentair WhisperFlo WF-24 (seems like single speed)
    Bel Air, MD 21015
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Leak in plastic can I caulk ?
    Is that on the suction side or pressure side of the pump?
    Mark
    suction
    Bel Air, MD 21015
    Apr 2015
    Brookline
    60
    I just fixed a issue similar to yours. I blew out the line first and then added suction with my shop vac. Once under suction I laid on the glue to the outside of the pipe and it worked beautifully
    Southern New Hampshire, 18x36 single roman end pool.
    what type of glue?
    Bel Air, MD 21015
    mas985's Avatar
    Pleasanton, CA
    11,741
    For a permanent fix, I would use marine epoxy. Anything else may not last very long.
    Mark
    Apr 2015
    Brookline
    60
    I used regular pvc glue. Marine epoxy will work to but my way gets it into the cracks way down inside
    mas985's Avatar
    Pleasanton, CA
    11,741
    PVC glue? By itself, I don't think that will hold for very long. Normally, you have to mix it with PVC pipe shavings so it will bond properly but on it's own, it won't bond properly.
    Mark
    Apr 2015
    Brookline
    60
    Well all I can say is It worked for me. I see your side of it too
