Results 1 to 7 of 7
Thread: Is this TA level too high
    Apr 2016
    Smyrna, TN
    4
    Here are my readings using the TF-100 test kit
    FC 4
    CC 0
    PH 7.5
    TA 110
    CYA 40
    12K gal, in ground vinyl, sand filter, using liquid chlorine.
    12,000 gal in ground vinyl, Hayward sand filter and Hayward pump.
    Jun 2014
    15,177
    Re: Is this TA level too high
    Not really. You have some flexibility with TA as it relates to its effect on your pH which is really more important to us. If your pH remains stable in the mid 7s, then leave TA alone. But if your pH rises quickly, you would want to lower TA in stages to see if it helps keep the pH down better.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Nope.
    If that's a brand new test kit, you might want to wipe the tip of the R-009 with a damp paper towel between drops. When new, that reagent can generate static electricity which makes smaller drops which makes things read higher than reality.
    Apr 2016
    Smyrna, TN
    4
    Nope.
    Thanks for the explanation, Yes it is a new kit. I read that in the instructions but I didn't understand why they recommended that and I was lazy and didn't wan't to go get a paper towel . I will try it again correctly, when I get home.
    jcowart's Avatar
    Jun 2012
    Labelle, TX
    320
    My two cents added to the other post that are spot on. Don't get carried away with a TA number. With a vinyl liner you will not be having the same issues with say someone with a fresh plaster pool. Check and adjust your pH and not worry about TA. Once your pH is stable your TA will be in it's happy home. Mine likes to live at 60, my FIL's likes around 80, and the next door neighbor... well he uses a target number given by the chemical salesman "pool store". Now if you start using tabs or solid chlorine.... that's another story.
    17500 gallon Doughboy AGP, Hayward DE filter, waiting for the 1.5hp DB pump to go out.
    Learn to take the advice here and be trouble free or use the pool store's advice. "You can't do both and get very far"
    Apr 2016
    Smyrna, TN
    4
    Thanks for all the responses. I checked it again wiping the bottle tip and got a reading of 90.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Good job lowering your TA by 20!
