Results 1 to 7 of 7
Thread: It's time!
    It's time!
    Pool was refilled last night- it had about 1/2 of water displaced to I had to do a partial refill...with that being said I had pump issues and the water sat all day today and now I can run pump. Should I let it circulate for 24 hours and then test CYA and chlorine amounts? or should I go ahead and test chlorine and SLAM it and then test CYA in a couple of days and adjust as needed? I am going to go ahead and bet that CYA is very low since I had to do a huge refill with new water....
    ITs hot here in East TN....82 today... Bring it on!
    21 ft Round Dough Boy
    3/4 horsepower Dough Boy PowerPak II pump
    Vinyl Liner
    baqua goo convert
    Jun 2014
    15,177
    Re: It's time!
    Run the pump for about an hour or so to mix well then test everything. You need a good (accurate) CYA to know what your SLAM FC should be. Also make sure to adjust pH to 7.2-7.5 before raising the FC. Good luck!
    Re: It's time!
    OK so check CYA first after an hour? if it is super low which I am betting it is- do I need to put in my stabilizer and wait till it fully dissolves and mixes then retest CYA (in a couple of days) water temp is cold too maybe 6ish...
    Then start the SLAM? Water is really clear now btw....or can I just get enough bleach in it until I can slam....??? and still be getting CYA up to normal level
    Vinyl Liner
    baqua goo convert
    Jun 2014
    15,177
    Re: It's time!
    If it's low like you think, measure and start soaking right away and just assume your water is at the new CYA target (i.e. 30 ppm). You can test it a few days later if you want. Yes, water temps below 70 can impact CYA testing. You could bring a sample in the house to warm-up a bit and test one more time outside if you wanted. Verify pH, then ... SLAM!
    If you aren't sure about the need to SLAM (i.e. clear water, no signs of algae), you can do an overnight (OCLT) test to be sure. Up to you. But whenever you SLAM, maintain that SLAM FC (i.e. 12 based on CYA of 30) until you pass the 3 SLAM criteria. Hopefully you won't take too long with clear water.
    Re: It's time!
    ok will do...since I am going to get CYA in it and top up to 30- do I just get some bleach in it based on that CYA level to start circulating? I am just fearful there is very little chlorine in it now with the refill---
    Vinyl Liner
    baqua goo convert
    Jun 2014
    15,177
    Re: It's time!
    Sure, increase the FC based on what you place in the sock and let it roll. SLAM!
    Re: It's time!
    Thank you
    Vinyl Liner
    baqua goo convert
