Thread: Taylor 2006 Reagent Reuse
    May 2015
    Roanoke, IL
    7
    2nd year TFPCer's simple question -
    Can I use the reagents from last summer or do I need to replace them when I re-open in the spring?
    They were stored in the garage all winter.
    Thanks!
    Installed 2003; 15K gal; IG Vinyl; Tagelus TA-60 sand filter; 1 HP Century/Centurion A.O. Smith BX3-18 single speed pump; Hayward H150 heater; solar cover; manually sweep; add water with softened well water
    JoyfulNoise's Avatar
    May 2015
    13,213
    Re: Taylor 2006 Reagent Reuse
    Quote Originally Posted by Raymundo View Post
    Thanks!
    Is the garage heated or temperature controlled in anyway?
    See this link - http://www.taylortechnologies.com/Ch...SP?ContentID=2
    They are probably good. In the future, the kit should be stored indoors in a cool dark space.
    Matt
    May 2015
    Roanoke, IL
    7
    Thanks for the link and information. I think it will be ok to use.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Look at the plastic bottles. If any of them are discolored, the reagent inside is bad. And if you get any readings that are way out of whack, it might be worth a dash to the local pool store to pick up the iffy reagent. They're standard Taylor reagents.
