Thread: Raising pH. Do I care about TA too?
    jeremy's Avatar
    May 2013
    Oceanside, NY
    54
    PH is 7.2
    TA is 50
    FC is 2
    Should I simply add Borax to increase the pH, or do I need to be concerned with the TA?
    POOL SPECS: INDOOR, 22.5k Gal, Vinyl Liner, L-Shape, In-Ground, Main Drain (2), Skimmer (2), Water Slide, No Spa/Water Features (Dimensions, Pool Pic, Panoramic Pool Pic)
    HARDWARE: Jandy DEV60 Filter / JEP1.5 VS ePump / AquaLink RS Controller, Sta-Rite SR400NA 400k BTU Heater,
    Jun 2014
    14,979
    Re: Raising pH. Do I care about TA too?
    Your TA is on the lower end, but not unreasonable. By adding Borax, it may also increase TA "slightly" as well. Lift the pH to the mid 7s now and see how it responds. If the pH still gets pulled "down" later, and the TA is still below 60, then you can always add a little baking soda later to raise TA to 60 and try that, then 70 if needed, etc, etc. Make sense?
    jeremy's Avatar
    May 2013
    Oceanside, NY
    54
    yes, makes sense. Will add borax now and check on the pH in a few days. Thanks!
