Thread: SWG when to turn back on
    Apr 2016
    Richmond KY
    2
    This is our 3rd year with our new pool. This has been an adventure and we learn something new each year. I am excited to be with trouble free pools and have read many things and just this day joined you.
    Our question is: I have a low salt level and have added sufficient amount required. However, when do I turn the SWG back on?
    Thank you,
    Mimirocks
    Our pool is an inground saltwater 16x32, concrete with liner.
    Jul 2015
    Central Valley CA
    1,108
    Re: SWG when to turn back on
    Most posts I see say 24 hours, probably don't need to wait that long if you have the pump running and do some vigorous brushing but it is a good safe amount of time.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Apr 2016
    Richmond KY
    2
    Thanks so much.
    Jan 2012
    'burbs of Augusta, Georgia
    7,351
    Its a good idea to have your own way of testing the salt level as sometimes the SWG is far off. You wouldn't want to waste money adding salt when it isn't needed, and likewise you might not be getting the chlorine production you need if your salt level is too low.
    Taylor's K-1766 Salt level test kit is what I use. I personally have found the strips unreliable although others have used them without problem.
