Thread: Sta Rite MaxETherm SR333LP issue.
    Apr 2016
    Brookfield
    3
    So upon opening the pool this year I went to turn the heater on and immediatly the service heater light came on. I popped the casing open and found mice. Did not appear there were any chewed wires after inspection. I remove the top cover and the AFS light was on. I tried to jump the connectors to bypass the afs. after bout 30 seconds the blower is seen kicking on and off withing a second and the "service heater" light comes on again.
    Trying to see where i should go from here.
    It should be noted that the blower motor housing gets very hot when the unit is left on even though the blower is not rotating.
    Thanks for the input
    Apr 2016
    Brookfield
    3
    Re: Sta Rite MaxETherm SR333LP issue.
    disregard went back and unplugged all wires and checked their connections. upon putting them all back it started right up.
