Page 1 of 2 12 LastLast
Results 1 to 20 of 30
Thread: First swim in new to me pool, Found significant green algae
    Nov 2015
    Carrollton tx
    451
    Guys
    The water was 75 this weekend
    so I got in for the first time to look around
    I found a bunch of green algae - mostly around corners of plaster and in the seams of lights and other items sticking from plaster
    I went ahead and brushed most of it that I found. The 90 degree Fiberstars fittings were basically full of algae and trash
    The swim jet had a mushroom size clump of algae or something growing near the controls
    The question is my FC is usually between 3 and 5 and my CC is typically zero
    The water is clear.
    Today I decided to throw a bunch of Cal Hypo in to raise the FC to 10 ish
    Is it normal to see this kind of algae even with decent chlorine numbers ?
    Doug - Purchased 1/2016, 1995 house with 16x31 ft, ~23000 gallon Gunite pool w 11x7 spa, 3 Pentair VS pumps, a boost pump for polaris 3900 and a BaduŽ Jet super-sport swim jet pump, 1.5 hp blower, a CL460 Cartridge filter. TF-100 test kit. Aquapure SWG, iAqualink - Lots to learn. New Aquabright, Jandy LEDs, CMP LED Sheers.
    Jun 2014
    14,970
    Re: First swim in new to me pool, Found significant green algae
    No amount of algae is normal, and unfortunately the Cal-Hypo may not be doing you too much good either. You need to "SLAM" via the link below in my sig. Please read that page very carefully and follow the instructions to the "T" while testing with your TF-100. A SLAM will work, but you have to stick with it. Let us know if you have any questions.
    Oh, and try to post a FULL set of numbers for us next time you get a chance. Thanks!
    Nov 2015
    Carrollton tx
    451
    PH is in the right range
    Ill run the full tests tonight
    The odd thing is that other than the algae that I found in some mortar joints and in the fiberstars the pool meets the Slam standard
    1. CC is 0.5 or lower;
    2. You pass an OCLT (ie overnight FC loss test shows a loss of 1.0 ppm or less);
    3. And the water is clear.
    One thing that likely is contributing to the issue is too little brushing
    But the areas that Im seeing issues wouldnt trypially get brushed from Pole brushing
    Jun 2014
    14,970
    Lack of brushing and/or poor water circulation around nooks & cranny's are contributors. But once we see your full set of test results, it will help tremendously. Weather is picking-up for us, so that also increases our ability to get algae if we let our guard down a bit. No worries though, we'll help you. Have a nice day.
    Nov 2015
    Carrollton tx
    451
    I added more Cal hypo per Pool math and I still cant get FC above 7
    It hadnt all dissolved and the storms blew some stuff in the pool
    After the system runs this morning Ill restest and add some bleach ..
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    3 jugs of 8.25% generic concentrated bleach will take you from 0 to 10 in 15 minutes.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,392
    Silver you get to B&B! LOL Bleach and brush! I would brush first then add the bleach to get your FC up to SLAM levels and keep it there for a few days while you brush some more. We need to get that algae out!
    Kim
    Nov 2015
    Carrollton tx
    451
    I have a little bleach, ( maybe a gallon ) looks like I need to take the hooptie to Walmart and buy about 10 gallons
    I was using the Cal hypo since the previous owner left about 60 lbs of it behind and I plan to use SWG once the pool is replastered.
    Im wondering if the cal hypo is so old its effectiveness is lowered or if the pool is just consuming it ...
    Thanks to everyone for the help and encouragement
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Nov 2015
    Carrollton tx
    451
    Great Idea
    While Im there
    DFW, TX
    24,450
    Hooptie! LOL! Most likely the pool is consuming it. What is your CH level? 60lbs? Must have been a sale! What % calhypo is it? Each lb will add about 3 ppm FC and almost that much CH.
    You can Perform the Overnight FC Loss Test (OCLT) to see how much chlorine your pool is using.
    Nov 2015
    Carrollton tx
    451
    There are 2 buckets - one 25 lbs of 73% that was almost full and a 100lb bucket of 68% that was about 30 % full
    Ive added 5or 6 16 oz scoops in the last 48 hours
    The pool has such a leak that maintaining any level is tough - ch , salt, cya anything -
    until the plaster is redone Ive just been focusing on the PH and the FC
    The hooptie is a 99 S10 pick up that is perfect for hauling bleach and other stuff that doesnt go in the SUV
    Nov 2015
    Carrollton tx
    451
    CCH left over
    Walmart pool sanitizer 10% and a little larger than the great value 8%
    A gallon and a little and Im finally up over 10ppm
    Apr 2016
    Murfreesboro, TN (Middle TN)
    103
    Man I got lucky and snagged some of that 10% chlorine at 2.50, used it all to slam and now none of my Walmarts carry it!
    27' above ground, 17500 gallons, Cartridge filter Hayward SW1000z4, A.O. Smith Pump SP1515Z1BC 70 GPM, Test kit Taylor TF-100
    Murfreesboro, TN
    Nov 2015
    Carrollton tx
    451
    Ok Here is full set of numbers
    After the predicted 2 gallons of bleach the FC is 12
    It was 11 early yesterday after a gallon+ of bleach then down to 7 last night
    the rest of the second gallon got it up to 12 and its stayed up over night
    CYA has dropped some - Im guessing due to rain and leak - Still have 2 floaters in the pool with pucks in them.
    FC 12
    CC 0
    CH 250
    TA 60
    PH 7.5
    CYA 20
    Jun 2014
    14,970
    Those are excellent numbers for a SLAM if you are indeed still SLAMming. Actually, it won't hurt you if the FC dips to 10 based on the CYA of 20. But be leery of a low CYA as often times when it's at 20 or so, it can actually lower than we think. Because of your leak(s), keeping a tab in there is probably a good thing right now to help with that CYA dropping. So keep those numbers where they are, keep scrubbing, cleaning the filter, and hopefully you'll see the SLAM work in your favor soon. Have a nice day. Nice work!
    Nov 2015
    Carrollton tx
    451
    Assuming that its ok to swim in water with FC of 10 I intend to keep it up there for 48 hours at least
    Give it time to get in all the knooks and crannies
    Ill go scrub the fiberstars lights again by hand to loosen up any renaming garbage
    May need to go buy a few more gallons of bleach while its $2.50
    Jun 2014
    14,970
    That is a good price. Our Wal-Mart had them as well, but the Julian dates were a bit old. Just make sure to maintain the SLAM FC level until you pass the 3 criteria so that you're not doing the "SLAM dance" again in a couple week.
    DFW, TX
    24,450
    It is safe to swim with FC up to shock level for your CYA, Chlorine CYA Chart
  20. Back To Top    #20
    Nov 2015
    Carrollton tx
    451
    Just need to pass the Over night test - But even so Id like to keep the FC level up for 48 hours no matter the results
    The Walmart chlorine dates were 80 th day in 2016 ( march 20 ) which isnt bad - i hope
